January 21, 2026, 03:39:40 pm
You are probably using greyscale color setting. I know how to change to RGB in Photoshop but it's different in Illustrator. Hmm try Edit->Edit Colors->Convert to CMYK or RGB. I don't use Illustrator much so it's a stab in the dark.
1) Click and drag to select the text. Than select the color you want from the swatches.
2) Go to the direct select tool (Black arrow) and selct the text box. You should see a box around the text. Pick your color and all text in the box will change color.
That's weird.
