Author Topic: Trying to decide on a coin door  (Read 1610 times)
clockwork
  • Last login:December 11, 2008, 11:15:29 pm
  • Time to play!
« on: July 06, 2008, 03:52:19 pm »
Originally I planned on not having one, now I think I want one. But I may or may not have a door on my cabinet. If I use an over/under model, I don't need a front cabinet door/access, right? If I use a single coin door, will I?
Also, it looks like the Happ models come pre-fitted with quarter coin mechs. Can these be made to work with BYOAC tokens or do I have to buy separate mechs?
« Last Edit: July 06, 2008, 04:25:55 pm by B-Stone »
Charlie Brown: I'm still hoping that yesterday will get better.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Trying to decide on a coin door
« Reply #1 on: July 06, 2008, 04:14:51 pm »
What is an "arcade door" ?
If you mean front-panel-access to you computer, then you might not be satisfied with the access a normal over/under would provide and might choose a bigger door (like a Happs 4-player or Midway/Atari/Coinco door).
If you want to convert quarter mechs to token mechs, see here, but bear in mind that you can always order token mechs instead of quarter mechs.
Working: Not Enough
Projects: Too Many
Progress: None
clockwork
  • Time to play!
« Reply #2 on: July 06, 2008, 04:28:05 pm »
I sometimes use "arcade" and "cabinet" interchangeably. Sorry. Yes, a front access. Reworded my post.
Thanks for the info.
CheffoJeffo
« Reply #3 on: July 06, 2008, 04:33:35 pm »
Dont worry about terminology -- I'm old (or pretty close to old, by WarGames standards!) so may not catch it.
Yeah, an under/over door doesn't give you much access through the front. If you want access through the front, my preference would be for a shorter, wider opening like a Happ multiplayer door or a CoinCo door (coincidentally, every MAME cab I have ever had has had a CoinCo door).
Working: Not Enough
Projects: Too Many
Progress: None
clockwork
  • Time to play!
« Reply #4 on: July 06, 2008, 05:42:42 pm »
Do you have a link to a good CoinCo model, and where to buy? Wider would be better than taller for me, even if I can make the panel open. I made my cab a bit shorter than standard.
For Happ, are you talking about something like this?
CheffoJeffo
« Reply #5 on: July 06, 2008, 06:04:18 pm »
CoinCo can be a pain due to different size (metric) mechs, but the door you linked to is right along the lines of what I was thinking of. It really depends what you want to be able to accomplish through the coin door.
Working: Not Enough
Projects: Too Many
Progress: None
Ken Layton
  • Guru
  • Technician
« Reply #6 on: July 06, 2008, 06:53:38 pm »
Coin Controls doors are metric and have not been manufactured for several years. What limited amount of parts are available for them still you can get from Happ Controls.
Coin Acceptors (a.k.a. Coinco) bailed out of the amusement coin door/acceptor market around 1995. Coinco doors are built to American measurements. Parts are now getting very hard to find as most NOS parts supplies have dried up. The only company I know of that still has a decent supply of parts for these is The Great Amusement Emporium. They only sell to game operators and they have a $500 minimum order requirement.
CheffoJeffo
« Reply #7 on: July 06, 2008, 07:05:44 pm »
Ack ... Ken got me (and wise advise is to ignore what everybody except Ken says) ...
So, ignore what I said about brands and look only at the size of the door that you want.
Thanks Ken for not letting myself make a bigger fool than I have.
Working: Not Enough
Projects: Too Many
Progress: None
