Author Topic: Mala Tree with 'Blue' Layout problems  (Read 2523 times)
RXII
  • Last login:March 27, 2014, 07:45:51 pm
    • Aussie Lowboy Buildup
« on: July 02, 2008, 02:23:26 pm »
Hi Guys,
                 A while ago I had Shock's Applesque layout running in a tree format with no problems, recently I have completed a reformat of my arcade PC (to a version of windows with network support....not Beast!) and decided on a change of look. I like the layout "Blue" but I cannot seem to get it to work in the tree format. I have attached a picture of the layout as downloaded to see if I am putting the folders in correctly, I dumped all of these folders directly into a 'layout' folder and pointed the layout there. I only want to use the 'blue1024' layout, I can get the layout to work fine without the tree but when I go to configure the tree only the 'standard' layout is available as an option.
Do I have to put the .dll file in the root directory of mala? I know it will be aan easy fix but at the moment its not obvious to me.  :dunno
Any help would be great
Thanks,
Simon.
Operation Aussie Lowboy http://forum.arcadecontrols.com/index.php?topic=68962.0
Soon I may actually be able to play it!
RXII
Re: Mala Tree with 'Blue' Layout problems
« Reply #1 on: July 04, 2008, 12:25:17 am »
Do I need to supply any more info for this???
Simon.
loadman
  • Moderator
    • MaLa
« Reply #2 on: July 04, 2008, 12:46:52 am »
I dunno. I have not used that one
Did you look at the tips here?
http://wiki.arcadecontrols.com/wiki/Mala_Layout#F.A.Q.
RXII
« Reply #3 on: July 04, 2008, 02:09:43 am »
Hi Loadman,
                       Yes I have read that, I just assumed that the layout had listed fine to use without the tree but it wont give me the option to choose it WITH the tree. This is Mala version 1.03 as 1.04 gave me an error when I used it as shell....I couldn't understand what the error was so I just went back to 1.03 where it works fine.
Thanks for the tip...I will persist.
Simon.
