Author Topic: ICE Trackball Mounting Question  (Read 1672 times)
pie taster
  • Last login:April 03, 2015, 09:21:51 am
« on: July 02, 2008, 11:52:54 am »
I'm getting ready to order the GGG 3" ICE trackball for my Wood Control Panel.
I'm confused on the mounting options to use that is on the GGG site.
There is a Super High Trackball Install Kit - Electric Ice-T and Imperial
And a
Trackball Mounting Kit - 3"
if i get the Install Kit.. do i need the  mounting kit.  Or should I just get both?
    • GroovyGameGear.com
Re: ICE Trackball Mounting Question
« Reply #1 on: July 02, 2008, 12:47:39 pm »
The two options are mutually exclusive.  The mounting plate is the old standby, which is probably the simplest install, but will give you a standard ball-height and a big square plate on your panel.  The "Super High Install Kit" is a bit more involved, but has the benefit of a much higher ball, and only a small circular bezel visible on your panel.
pie taster
Re: ICE Trackball Mounting Question (question answered)
« Reply #2 on: July 02, 2008, 01:13:03 pm »
Thanks Randy.
cmoses
« Reply #3 on: September 03, 2008, 10:31:36 am »
Randy,
Can you tell us the differences in height between the balls when mounted with the standard mounting plate vs. the super high install kit?  I am considering the super high install kit as it does not need a mounting plate but am not sure how much it will stick out?  Can the amount that it sticks out be adjusted by using washers or spacers?
« Reply #4 on: September 03, 2008, 06:43:58 pm »
The apex of the ball is very close to 1" above the actual panel surface with the "Super High" install kit.  A standard trackball apex is about .575" above the panel surface.
Yes, but the drawback would be that the ID of the finishing ring would then be too large.  A better answer would probably be "yes, but you probably won't want to once you see / feel it" ;)  Also, keep in mind that the finishing ring actually reduces the overall visible height of the ball by about 1/8".
