Author Topic: CONFIGURING MAMEWAH 95 FOR ZSNESW AND VIRTUANES  (Read 2081 times)
colonelsnow
  • Last login:July 13, 2022, 07:56:26 am
« on: June 04, 2003, 06:57:32 pm »
Has anyone gotten either of these to work? If so can you give me your set up?
Re:CONFIGURING MAMEWAH 95 FOR ZSNESW AND VIRTUANES
« Reply #1 on: June 04, 2003, 07:35:22 pm »
Go into 'Emulator Settings' > 'Execution Settings'
For ZSNESW, Check these options:
Send ROM Path = Yes
Send ROM Extension = Yes
Use Long Filenames = Yes
Show DOX Box = No
I suspect 1 or more of those may be the cause of your problem...let us know if not.
Sorry, I have not tried the other emulator, but try out some of the above options.  Also, look in the MAMEWAH installation folder for a file 'debug.log' after you have tried to launch a game - this file shows how MAMEWAH has 'tried' to launch the emulator.
colonelsnow
« Reply #2 on: June 04, 2003, 09:03:34 pm »
Thanks those settings worked for both emulators.
Now I can not get the screenshot renaming to work.
In Mamewah I have the artwork1 path set to c:\snes which is where I have Zsnesw set for my snapshots
In the rename section in mamewah I have it set to c:\snes\image.bmp What I am I doing wrong?
« Reply #3 on: June 05, 2003, 07:04:12 am »
Hmmm, I just quickly tried this - it didn't work for me either (your setup looks OK).
It looks as if this feature may be broken this version - has anyone else got it to work?
I'll check it properly soon, and fix it if it's broken.  :)
« Reply #4 on: June 05, 2003, 01:50:22 pm »
OK I just checked and it seems I commented out the code for the Snap Replace option and forgot to add it back in, that's why it didn't work  :-[
All fixed now tho :)
colonelsnow
« Reply #5 on: June 05, 2003, 07:39:19 pm »
How can I get the corrected version?
I e-mailed you my files folder also.
« Reply #6 on: June 05, 2003, 07:59:51 pm »
You'll have to wait for the next release (soon)...
