Author Topic: Basic shift functions MiniPac  (Read 1779 times)
Blanka
« on: July 01, 2008, 03:40:36 am »
Browsing the wiki and scroogling I did not find it.
I am looking for a list with the default shift-functions of a MiniPac
So a list with which key is shift by default, and what functions are hidden under which other keys.
Does anyone have that?
Ginsu Victim
  • Comanche, OK -- USA
Re: Basic shift functions MiniPac
« Reply #1 on: July 01, 2008, 08:30:38 am »
removed by Ginsu Victim
« Last Edit: July 01, 2008, 12:10:36 pm by GinsuVictim »
Blanka
« Reply #2 on: July 01, 2008, 09:25:41 am »
MMM, I was hoping to have the return key somewhere too  :(
Strange the vwxyz buttons  :o
Ginsu Victim
« Reply #3 on: July 01, 2008, 10:00:10 am »
Then you just program it.
ahofle
    • Arcade Ambience Project
« Reply #4 on: July 01, 2008, 11:07:00 am »
Hmm are the shift defaults different for the minipac than the ipac?  Because I have ~, P, Enter, and tab (way more useful for MAME) instead of the ones you listed for the P1 joystick directions.
Ginsu Victim
« Reply #5 on: July 01, 2008, 11:35:58 am »
Since I don't have mine set to the defaults, I just opened the software and loaded up the default layout. Guess that's not the default, then.
ahofle
« Reply #6 on: July 01, 2008, 11:48:54 am »
Found the IPAC defaults.  Not sure if they differ from the minipac though (although I would surprised if they did)...
http://www.ultimarc.com/ipac2.html
Ginsu Victim
« Reply #7 on: July 01, 2008, 12:11:03 pm »
No, I'm pretty sure that's right for the minipac as well. I removed my post.
Blanka
« Reply #8 on: July 01, 2008, 12:33:13 pm »
There is standard button for enter as well
Only to find out i reprogrammed the thing long time ago. But I found a mac-utility for programming, and now al keys work like i want them too work.
nukedawg
  • Last login:May 08, 2021, 10:25:12 am
« Reply #9 on: July 01, 2008, 05:32:21 pm »
The Mini-PAC works identically to I-PAC2 board. All programming features identical, same number of inputs (28).
quoted from http://ultimarc.com/minipac.html
So it should be identical as far as software is concerend
