Author Topic: arcade chassis  (Read 1842 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
arcade chassis
« on: June 29, 2008, 06:05:14 pm »
do picture quality varies from chassis to chassis because i have a weyia 826 and it looks good on the 80s games but it looks like crap on the 90 games
grantspain
Re: arcade chassis
« Reply #1 on: June 29, 2008, 06:32:55 pm »
the simple answer is you get what you pay for
you see many variations of quality,for example if you offer up a nanao ms9 next to a hantarex polo the difference is unbelievable in regards to scan lines
weiya is at the cheap end of the market so its all about costs
the best monitor i have seen recently is the new sanwa tri sync,its about double the cost of a rodotron or weiya
alienware32
Re: arcade chassis
« Reply #2 on: June 29, 2008, 06:35:30 pm »
do you think i should try a 8 liner chassis on my 27 tube
grantspain
Re: arcade chassis
« Reply #3 on: June 29, 2008, 06:42:08 pm »
what exactly is happening with your present chassis,are you getting heavy scan lines or lack of definition
alienware32
Re: arcade chassis
« Reply #4 on: June 29, 2008, 07:07:21 pm »
both like i said the 80 games pacman donkeykong look fine but newer games like street fighter  dont have no definition
grantspain
Re: arcade chassis
« Reply #5 on: June 29, 2008, 07:20:32 pm »
if you talking arcade boards then maybe the quality of the chassis is in doubt
if you are talking emulator of some kind then its something to do with your setup
alienware32
Re: arcade chassis
« Reply #6 on: June 29, 2008, 07:22:36 pm »
yes it a mame setup I'm using soft15 and a redeon 8500 video card
