Author Topic: MAMEUI32 - how to disable coin option? Keep having to press 5 on keyboard.  (Read 9049 times)
vetteguy112233
  • Last login:April 28, 2012, 12:15:24 am
I don't want to keep pressing the "5" key on the keyboard to "add coins", is there a way to disable this feature?
Dizzle
  • Last login:August 09, 2014, 05:28:04 pm
Under settings, there's a place you can set "free play" to on.  Is that what you had in mind?
vetteguy112233
Yes, but I can't find that setting anywhere. Could someone please point me to it?
TheShanMan
    • My Arcade (updated 1/30/13)
I believe only certain games support free play - I don't think it's a feature of mame. I don't think there's a direct way to avoid coin input. However, you could try mapping both coin 1 and start 1 to the "1" key. Maybe that would work.
amiga500
  • Last login:December 29, 2024, 10:09:10 pm
Press F2 into the game to access "Service Mode", you'll find an option called 'Coins configuration or 'System', select 'Free Play'. Every game is different so not all games are configured the same way. Also I found a lot of games that not have the 'free play' option.
If you press TAB on the game you'll access the MAME menu and you'll see a 'Dip Switches' option, you can set Free Play from here too, If the game allows it.
cheers :cheers:
Blanka
I'll vote for an auto-quarter option in Mame! I play 1944 a lot, and than you just don't want to insert quarters everytime you crash.
Even better: cross-mame quarter management. If you press 5 30 times, you will have 30 quarters for all your games. If you play Pac-Man, Pac-Man will still show 9 quarters, but the ammount does not lower on the first 21 game-starts. If you insert 30 quarters and you play 5 instances of Pac-Man and 17 on 1944 and 4 on arkanoid, you still have 4 quarters if you start Joust. Add OV-Chipcard support to it as well, and people can hack these Dutch train-passes to gain unlimited Maming for 0€.
nipsmg
  • Last login:February 15, 2026, 06:33:19 pm
  • ROONEY!! ERRGH!!
    • Arcadia
This type of thing (cross quarter management) I think would encourage the use of mame in illegal money making situations.
I'm going to leave out the whole "MAME is a documentation project, playing is a bonus" rhetoric here but I don't picture these features being added any time soon, if ever.
You can play nearly every arcade game ever made at home for free..... JUST PUSH THE DAMN COIN BUTTON!  ;D   ;)
Minwah
    • MAMEWAH
I must admit I don't get it. It's not particularly hard to press a key.
Jdurg
Not to mention that it really would make no sense with regards to functionality either.  People always seem to forget that MAME is not one emulator with every game linked to each other.  It's really a big compilation of thousands of emulators, one for each game.  When you run a game, it is as if you are plugging the cabinet for that game in and turning it on.  When you exit the emulation, you turn off the cab and unplug it.
It would introduce a TON of overhead to try and get the credits to move from one to the other.  The good thing about MAME is that it is open source.  If you want to code it yourself to do just that thing, there is absolutely NOTHING stopping you.  You'll just have to do it each and every time you update MAME.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
Ginsu Victim
  • Comanche, OK -- USA
You can't setup a shifted credit button? I have a shifted credit, just in case I don't want to put coins in.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Start a game, press tab, select "Input (general)", select "Other", and remap coin 1 to a button on your control panel (or gamepad, or whatever you're using).  Then you don't need to use your keyboard.
"Disable" how?
Change the default buttons from the "5" key to something else?  Yes. (see above)
Disable emulation of the original arcade game's game play?  No.  (mame is about emulates as much as possible as close as possible)
Use the original game's freeplay (if it had it)?  Already does.
Add freeplay to game's that didn't have freeplay?  No.  (that involves either hacking the original game, or disabling emulation mentioned earlier.)
And if you don't have a enough buttons on your CP/gamepad/controller, just map a button combo.
Robin
Knowledge is Power
Blanka
The 5 button was figuratively speaking. I already have it as pushbutton on the CP. But you have to move your hands up while gaming. Maybe I should connect it to the BOMB button in 1944. 1 credit everytime I unleash a bomb. After 4 bombs I die anyway, so I need new credit. That way the credits add not too much noise to the gameplay. Imagine using the fire-button as coin button as well :).
ratsflif
  • Last login:January 29, 2024, 06:08:07 pm
I like having to insert the coin each time, it reminds me of how much money it would have cost me back in the day playing on the real machine.  I have a 4 player mame cab with a coin door and I added a button above each coin slot that inserts a coin so I have to reach down and hit it each time.
Space Fractal
  • Space Fractal
    • Space Fractal
Credits is the charm when playing arcade games.
If you dosent have a credits coin. You can as others say, just map the coin button it to PL1 start as well, so the same button act like insert coin and start the game as well....
Ginsu Victim
I've heard this can create problems with some games, though.
ahofle
    • Arcade Ambience Project
 :laugh2:  Someone needs to make that their sig or something.
Sometimes I wonder how the mamedevs keep from imploding.
Ginsu Victim
Some people feel so "entitled" to these games that spending even virtual coins bothers them.
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
Half the fun was saying, "Oh @#$%, I only have one quarter left", searching trough your pockets and saying "@$#%!!!  I'm out of quarters, lemme borrow one".  I was playing a D&D game and decided to fight a Red Dragon.  $5 later, I won.
Ginsu Victim
My wife and I play beat 'em ups together all the time, and I always empty the coin bucket first. When we beat the game, we count up how much we spent.
Shocking at times.
Let's not even get into how much we've put into Metal Slug games.
