Author Topic: What games use 8 buttons?  (Read 4213 times)
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« on: June 03, 2003, 08:14:34 pm »
I will be going the ipac route, which will give me 8 buttons (Plus 2 more for start and coin).
But is it even worth using 8 buttons? What games ever use that many? (on MAME at least). Or do most use 6 buttons?
OR does Mame really require 8 buttons to get the most use.
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
Re:What games use 8 buttons?
« Reply #1 on: June 03, 2003, 08:17:30 pm »
MAHJONG! ;D
not many, basically mahjong games, i dunno about any good games that use 8
It's all about the Pentiums
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: June 03, 2003, 09:00:46 pm »
having those extra inputs allows flexibility.
Ladro
  • Last login:June 06, 2003, 10:14:10 am
« Reply #3 on: June 04, 2003, 01:11:46 am »
Defender Stargate has eight buttons
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #4 on: June 04, 2003, 01:17:16 am »
Console games.
Blech.
If you build a frankenpanel, chances are I don't care for you as a person.
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
« Reply #5 on: June 04, 2003, 05:34:38 am »
You can use the 8th button for each player to great effect. On the cabinet I just sold I had an I-pac with the 8th buttons mapped to various functions i.e. a pause button in Mame (dead handy for those 'phone rings as I'm fighting the end of level boss' moments) and a button for changing emus in Arcadeos, you can map them to whatever you like really as long as your frontend and emulator allows it.
Dexter
zorg
« Reply #6 on: June 04, 2003, 06:22:53 am »
for the 8 button's games you will find a list here http://www.mame.dk/?special=8buttons
same for the 6, 5, etc replace the 8 in the url by the number you want.
I'm on the planning stage
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: June 04, 2003, 08:09:10 am »
Huh?  Six plus Joystick up/down:
Reverse
Thrust
Fire
Smart Bomb
HyperSpace
Invisio
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: June 04, 2003, 08:11:46 am »
Most of those games are driving games meaning four buttons (maybe gas and brake which are analog inputs) and 4 gears (which would map to the joystick diagonals), so less than 8 button inputs required.
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: June 04, 2003, 08:33:00 am »
eight buttons plus 4 more for start and coin (2 each), but . . .
I use Buttons 7 and 8 for rotate left / rotate right with mechanical rotary joysticks.  Otherwise, you can use them for some other function as others have said.
It's personal opinion, but many people use six button inputs in a seven button layout (for Street Fighter, and Neo-Geo), either:
   1  2  3
   4  5  6
 1
or
    4  5 6
    1  2 3
 6
If this helps
RedSquirrel
« Reply #10 on: June 04, 2003, 10:44:54 am »
thanks guys much appreciated  ;D
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #11 on: June 04, 2003, 11:24:00 am »
Stargate uses 6 buttons.  I use the 7 & 8 button inputs on player 1 and 2 of the I-Pac for "Esc" "Pause" "Tab" and "enter" buttons (need to use the ultimarc programming utility for that)
:) Rotate or die! :)
Gopherboy
  • Last login:June 04, 2003, 06:44:40 pm
« Reply #12 on: June 04, 2003, 06:49:38 pm »
Hi Red,
Stuff functionality - I vote aestheticism every time! I have a layout very similar to Tiger-Helis except I use a fourth button on each row. (i.e.:)
               x     x     x
        x
               x     x     x
        x
Just looks better. (oh, of course, it can be mapped to whatever you want as well!) This is mainly because I have the top row red and the bottom blue, so it is good to have it even.
sorry - no real content to this post   :-\
gb
RedSquirrel
« Reply #13 on: June 04, 2003, 08:38:19 pm »
Thanks. I think I am just gonna go the standard 6 button route for the control panel, and use the extra buttons elsewhere for a pause and something else.
Tiger-Heli
    • Tiger-Heli
« Reply #14 on: June 05, 2003, 06:33:17 am »
You did pick up that I said seven buttons and six inputs, right?  (Meaning that the seven button layout won't keep you from having an input available for Pause and whatever).
Six button layout is fine as long as you don't want to play Neo-Geo fighters.  See http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=7970;start=msg58242#msg58242
RedSquirrel
« Reply #15 on: June 05, 2003, 06:43:39 am »
As in, wire two of the switches to use the same key?
Tiger-Heli
    • Tiger-Heli
« Reply #16 on: June 05, 2003, 06:55:26 am »
Quote from: RedSquirrel
[quote
Exactly!
