Author Topic: Keywiz help  (Read 1185 times)
Firehead
  • Last login:June 23, 2008, 05:24:30 pm
Keywiz help
« on: June 18, 2008, 05:17:45 pm »
Hi guys! How many led can be connect in parallel to the 5V+ on a keywiz usb?
Firehead
Franco B
Re: Keywiz help
« Reply #1 on: June 19, 2008, 02:26:47 am »
It depends on the LEDs forward voltage and the LEDs forward current.
If you know the specs of your LEDs you can use [this] calculator to design a parallel array.
Note, you want to keep the total current drawn under 500ma so you don't damage your PC.
If I put in the specs of some of the LEDs I have into that calculator (3.4V, 30ma) it looks like I would theoretically be able to connect 16 of those LEDs in parallel whilst drawing 480ma.
