Author Topic: Vga wireing plz help!  (Read 2613 times)
Jox43w
  • Last login:May 22, 2009, 05:55:28 am
« on: June 16, 2008, 10:34:54 am »
iv just picked up a scart and vga cable to make my vga to scart cable but i dont have a multimeter and dont know which whire are for which.
i have red green and blue
then i have  light green pinky light red are theese red and green (return) or (ground)?
if so what colour would blue ground be?
im trying to match the cables to the pin numbers on the end i cut off but the very base has been kind of coated in a plastic shell which has all the wires stuck togeter and is really hard to tell but from what i can see pin1 on the vga is a black wire wtf??
plz healp been looking foward to getting this done
grantspain
Re: Vga wireing plz help!
« Reply #1 on: June 16, 2008, 11:02:53 am »
colours vary,get a multimeter so you don't have to guess-it will save you a lot of bother
Jox43w
« Reply #2 on: June 16, 2008, 11:05:08 am »
so you cant just go by the colours? this would make sense as iv using a battry and my mouth to test which wires are which and the coulers so far arer completly wrong! lol
Jox43w
« Reply #3 on: June 16, 2008, 11:55:40 am »
ok i follwed the wireing guide on this site and iv just tested it and im getting a very faint black and white picture? :banghead:
grantspain
« Reply #4 on: June 16, 2008, 12:17:32 pm »
well you have done something wrong,tv set to the correct input and correct scart?
northerngames
  • Trade Count: (+18)
« Reply #5 on: June 16, 2008, 12:24:48 pm »
you discharge with that thing too?  >:D
« Last Edit: June 16, 2008, 12:29:27 pm by northerngames »
Jox43w
« Reply #6 on: June 16, 2008, 12:32:39 pm »
everything on the tv is set rite iv checked the cable and it all seems good only thing i can thing is i didnt add any reesitors or addin voltages because i wanted to switch av manuly but iv heard people use a battry connected to pin 16 to make the tv switch rgb? how do i connted the barrty + and - wires both go to pin 16?
grantspain
« Reply #7 on: June 16, 2008, 12:52:53 pm »
16=+
18=-
grantspain
« Reply #8 on: June 16, 2008, 01:10:16 pm »
what are you making a vga to scart for,scart will only accept 15khz so unless you are giving a 15khz signal it will not work
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Jox43w
« Reply #10 on: June 16, 2008, 03:02:59 pm »
i added a aa batery and OMG THIS IS AMZING  ;D
grantspain
« Reply #11 on: June 16, 2008, 03:42:44 pm »
why,is it working or did it explode :blowup:
Jox43w
« Reply #12 on: June 17, 2008, 10:38:27 am »
yeah its working and it looks amazing i love it i do have one prblem tho espx also runs fine but nulldc will not work when connected to my tv! it runs fine on the pc monnitor but when i select my other output it just dose not load any idea what could be casing this?
