Author Topic: vertical display config  (Read 1166 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
« on: June 12, 2008, 05:40:09 am »
im doing a vertical only cabinet using a scart tv and arcade vga.
my question is , what softwar/config do i use to get the pc and mame to boot up in vertical mode ?
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: vertical display config
« Reply #1 on: June 12, 2008, 09:40:37 am »
Use mala as your front end-it has all the vertical options you'll need. I have a vert cocktail machine and what happens is that windows will come up horizontally, but mala is rotated for the correct orientation when it loads.  (there are settings in mala for rotating it)
With the arcadeVGA you should use the auto resolution tool to create .ini files for every game.
When you launch the game from mala, you may have to use the tab->video options->rotate view to get the game into the right orientation.  You'll have to do that for each game, but only one time per game.  (that's part of the fun of MAME anyway-trying them ALL out!)
-jeff!
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: June 12, 2008, 09:55:45 am »
You can use AtomicFE as well.  Check it out.
Look at the wiki here :
http://wiki.arcadecontrols.com/wiki/Front-Ends
To have a list of all Front End working vertically.
