Author Topic: Optipac?  (Read 1266 times)
Rturb0
  • Last login:September 18, 2011, 08:57:28 pm
Optipac?
« on: June 11, 2008, 10:52:08 pm »
I bought an "optipac" and two rotary joysticks off a fellow arcade collector.
However, when I connect my USB to Serial cable to it, it is not recognized in windows.
Is this an old version that doesn't support USB? Could it be that I am just not using the right cable?
Thanks in advance
slsimon
  • Last login:February 16, 2012, 11:49:12 am
Re: Optipac?
« Reply #1 on: June 12, 2008, 02:50:48 pm »
Not sure if the optipac you have is an older version or not, but the optipac I have is a little different than the one shown.  Attached is a pic of the optipac I have.  The jump setting is noticable different.  Try changing your jumper settings to match the attached pic.  Thanks, Shane
Hoopz
  • Intellivision Rocks!
Re: Optipac?
« Reply #2 on: June 12, 2008, 03:51:06 pm »
Email Andy at Ultimarc.  He'll answer you straight away.
