Author Topic: Capkit help in Seattle:-)  (Read 1677 times)
BASS!
  • Just have fun.
« on: June 06, 2008, 08:24:01 pm »
Hello there!
I have a sony pvm with some minor convergence and geometry issue that I think a capkit will help solve. I am looking for someone in the Seattle area who could do this for a fee for me. I have done a great deal of soldering, but due to the fact that this is a old heavy duty monitor with very brittle boards, I don't want to take any chances. I will be posting a thread in the for sale area in case this doesn't get seen. Thanks a ton in advance, Im not trying to be lazy, just smart :)
Zebidee
  • Last login:February 18, 2026, 09:18:11 pm
Re: Capkit help in Seattle:-)
« Reply #1 on: June 08, 2008, 12:39:13 pm »
I really don't think that you should be rushing into getting a capkit done on your monitors.  There are other ways of addressing convergence and geometry issues, if they are really that big a deal to you.  Capkits are unlikely to make improvements here.
BASS!
  • Just have fun.
« Reply #2 on: June 08, 2008, 07:10:20 pm »
My only issue is that the pots that adjust the convergence on this board are so bad/ brittle that they will not adjust at all. I have measured the ohms on 2 of the pots and I get absolutely no change in my reading. I'm not meaning to rush into anything, I just figure while I'm tracking down new pots I may as well give it a capkit so that I take out two possibilities at the same time. I would also be willing to do the job myself, but due to the fact that no schematic is available on line, and there are not kits available, I just wanted to do as stress free of a job as possible.
Considering that you have used these in your projects, what would you recommend to possibly make the convergence a little more clear, and some waviness in the corner a bit better.
Zebidee
« Reply #3 on: June 08, 2008, 09:04:39 pm »
This might just be because of your measuring tool's sensitivity setting, or perhaps because there will be no change because of the ranges set somewhere else on the monitor.
Don't rush into changing the pots either. I think you are making unnecessary work & stress for yourself.  Dodgy pots are more likely to be loose and/or be 'crackly' when you adjust them.  Sony pots are a bit stiff so that they don't move accidentally - this is normal.  Use a good tool and a firm but gentle hand.
I haven't managed to track down schematics either.  I have used the Sony PVM2730's before, which should be very similar.  There are a large number of pots for making fine adjustments on the back and left side (right side if looking from the back).  These can be used to make some fine adjustments to your convergence ("dynamic convergence").  However, they don't really make any difference to the visible screen size.  You might be able to improve the "waviness" that you talked about, but I can't be certain.
Make sure that you mark the original positions of the pots, and adjust them one at a time.  If you can't work out what one does, make sure that you return it to its original position.  Some pots will not give a visible result.  You may need to adjust more than one pot to get the changes you want.
For more serious convergence issues, you need to look at adjusting the yoke and/or the multi-pole magnets (the cluster of rings) at the back of the CRT (this is the "static convergence").  I wouldn't rush into this either as it is a pain in the arse.  With the Sony PVMs, there are multiple PCBs and the boards are clustered around the back of the yoke, making this an even bigger hassle.  Avoid if possible!
What is the "waviness" you mention?
