Author Topic: Sony PVM Series Monitor Questions..  (Read 35385 times)
mike boss
Re: Sony PVM Series Monitor Questions..
« Reply #80 on: October 01, 2009, 01:26:48 pm »
Something tells me you guys are %100 on the money with respects to trying the RGB connection. However myself I would have no idea as to who to fabricate this cable.
I will however see if I can locally source it and give it a shot.
Im happy with the image I get now,but I know its way lacking.
mike boss
« Reply #81 on: October 01, 2009, 01:33:37 pm »
I just wanted to add I appreciate all the input and advice you guys gave me.
I thank you all very much.
I'm very much new to this hobby and often find I second guess myself.
Its a major reason as to why some of my projects have stalled, however Im forever gaining confidence in this hobby. My PVM monitor was an example of that. On the norm I would have never opened it up. But upon doing so I was able to use some logic and figure out a possible resolution. It would not have been without the help of you guys and the reassurance I found. So again thanks. I really like being involved in a community of people with like interests.
Ummon
  • Trade Count: (+13)
« Reply #82 on: October 04, 2009, 03:04:56 am »
Hacking a cable is basically doing what the manufacturers do in the first place: they solder wires to a connector interface. In this case you get a DB25 that fits the jack on your monitor; leaving a little slack on the connector side, you cut the DB15 off one side of a VGA cable; you open up that side to see the wiring connections and match that with a VGA pinout you find online; then you solder the corresponding wires of the cable to the DB25 connector per the instructions in my thread linked by Zebidee.
Yo. Chocolate.
Stephen Hawking
mike boss
« Reply #83 on: October 20, 2009, 02:22:32 pm »
I'd love to see how good these cables could look, I can tell that the s-video is not providing me with the optimum picture. BUT BUT BUT I won't complain, its playable. That onto itself is massive.
MAME is done as I noted prior : http://www.mymissiontomame.blogspot.com/ (THANKS!)
I will at some point see if locally someone can help me with these cables.
But for now I'll settle with the s-video.
Zebidee
  • Last login:February 07, 2026, 01:57:20 am
« Reply #84 on: October 21, 2009, 06:32:01 pm »
Why not ask Ummon to do the cable for you? He has the experience now. I'm sure that you guys could come to some mutually acceptable arrangement.
Jack Burton
« Reply #85 on: October 22, 2009, 03:27:59 pm »
If you're uncomfortable soldering a cable to a db25 connector this may be a good alternative:
http://cgi.ebay.com/DB25-Female-Signals-Breakout-Board-parallel-port_W0QQitemZ300351882760QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45ee5e0608
combined with one of these:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10212&cs_id=1021201&p_id=1591&seq=1&format=2
You won't have to buy it from monoprice.  You can probably go to your local used computer parts store and pick one up for a dollar or so.
« Last Edit: October 22, 2009, 03:31:00 pm by Jack Burton »
Ummon
« Reply #86 on: October 23, 2009, 03:05:18 pm »
That's a damn good idea, Jack.
<later>
....wait a minute. If you're gonna chop a cable an all, you might as well solder it. But at the very least, I doubt that PCB unit is heavy enough to worry about needing to relieve any physical stress on the monitor input.
« Last Edit: October 23, 2009, 04:52:52 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
