Author Topic: How do I get rid of this yellow number? (ArcadeVGA)  (Read 1418 times)
XYXZYZ
  • Last login:April 14, 2024, 04:12:37 pm
« on: June 03, 2008, 03:08:57 pm »
I have an ArcadeVGA2 AGP, and a vertical arcade monitor. Whenever I run an emulator that switches the resolution, there's a yellow 2 digit number in the top left corner, usually displaying between 50-60. I imagine it's displaying the framerate.
Is this some function of ATI tools? Does anyone know what I'm talking about, or how to get rid of it?
ahofle
    • Arcade Ambience Project
Re: How do I get rid of this yellow number? (ArcadeVGA)
« Reply #1 on: June 03, 2008, 03:15:03 pm »
Sounds like the vertical refresh rate.  What kind of monitor are you using?  I'm fairly certain it's not the AVGA2 as I have that same card and have never seen this.
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: June 03, 2008, 03:32:02 pm »
Some software like Fraps does this. If you have Fraps running you can turn it off.
It could be a function in the ATI tools or some digital display of the monitor. My old CRT used to display the refresh rate when changing resolution.
mcfreak
  • Last login:March 01, 2021, 01:55:04 pm
  • Asteroids moving along...
    • Hobby Blog
« Reply #3 on: June 03, 2008, 03:57:54 pm »
Is it just MAME?  If so F11 turns the framerate on and off...  If it is all d3d games/apps it could be in the video card or directx settings.
