Author Topic: Is This CPU Overkill For MAME?  (Read 1680 times)
lettuce
  • Make It So!
« on: June 02, 2008, 03:40:42 pm »
I starting a new project, and deciding on the PC components to go in my cab would a, Intel Core 2 Duo E7200 LGA775 'Wolfdale' 2.53GHz CPU be overkill for MAME?
massive88
Re: Is This CPU Overkill For MAME?
« Reply #1 on: June 02, 2008, 03:42:10 pm »
Depends on what games you are hoping to run.
lettuce
  • Make It So!
« Reply #2 on: June 02, 2008, 03:51:42 pm »
The newer 3d games, Gauntlet legends, Tekken series etc
massive88
« Reply #3 on: June 02, 2008, 03:56:18 pm »
Then no it wont be overkill.
You probably wont get Gauntlet Legends running at full speed either.
Im currently using a Core 2 Duo at 3.2ghz, and my gauntlet legends clocks in at around 90% speed during gameplay.
More Information:  http://forum.arcadecontrols.com/index.php?topic=72776.0
If you want to maximize your performance as well, you need to think about using a 64 bit OS and compiling your own 64 bit mame binary.
In my personal tests, I didnt see a difference between Vista and XP (64bit versions of both) performance wise.  I didnt get around to testing Linux before I went ahead with XP64.
« Last Edit: June 02, 2008, 03:59:46 pm by massive88 »
