Author Topic: T-Molding Question  (Read 1295 times)
jholman76
T-Molding Question
« on: June 02, 2008, 12:04:19 pm »
I'm building a cabinet and had a question about T-Molding.
When I put it in on the sides, I am starting on the back side and going all the way around to the front. My question is should I do the underside, where it sits on the ground, too? Would that be helpful to protect the plywood (im doing a furni-cab) from chipping? Or should I stick with rubber feet?
K Thx Bye
Joe
Level42
Re: T-Molding Question
« Reply #1 on: June 02, 2008, 01:28:52 pm »
Depends on the cab, but you can't use T-molding to let the cab rest on. It's not suitable to carry the weight, if you move the cab, it could very well get damaged or loose at least.
jholman76
« Reply #2 on: June 02, 2008, 01:30:23 pm »
Ok, that is what I was questioning.. I have some rubber feet I will use on the bottom. I still plan on t-molding the back, top and front, just not the bottom..
Joe
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: June 02, 2008, 02:25:56 pm »
Install leg levelers or wheels. Don't just let your cab sit on the floor.
As for the t-molding, it looks better (IMHO) to have it on bottom. I started in bottom middle, and worked it around until the ends met.
