Author Topic: a cool trick i accidentally figured out  (Read 1241 times)
Distortion
  • Last login:June 10, 2016, 04:39:20 pm
  • Saints Row 2, Sucka
    • Volition
« on: June 02, 2003, 01:16:22 pm »
Alright, so I thought I'd try using wingnuts for my joysticks.  Only one problem...they hit the sides of base unit.  But this worked out pretty nicely.  I can just take a screwdriver and screw it in from the top without having to touch the nut underneath when it gets loose.  The wingnut stays in place since it's hitting the side.
Game programmers do not play games for a living.  Would you say a mechanic drives cars for a living?
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
Re:a cool trick i accidentally figured out
« Reply #1 on: June 02, 2003, 02:00:58 pm »
I used something similar to this for the hardtop on my jeep :)
The top itself sets on the bodyframe, on the underside of where it sets is a thin channel, just large enough for a nut
This got to be a pain in the rear because you had to do some wicked contornionist tricks to get a wrench or socket in there, while also using a wrench or socket on the top to get it off or on(depending on if it was april or october)
Found some large wingnuts that fit my bolt size, once I got it threaded from the top, the wings would wedge into the channel and make it a snap
