Author Topic: How do you drill 1 1/8 holes into Metal?  (Read 2003 times)
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
« on: June 02, 2003, 12:11:48 pm »
I have a new arcade cab that uses a metal control panel.  I just need 3 more extra button holes in it.  How do you drill 1 1/8 holes into Metal? I have drilled in plywood and MDF before but I hate to chew up my spade bits on the metal.  Any ideas?
locash
  • Last login:March 22, 2008, 06:45:21 pm
  • Got cash?
Re:How do you drill 1 1/8 holes into Metal?
« Reply #1 on: June 02, 2003, 01:18:47 pm »
Whatever you do, don't try the spade bit.  That's a good way to break your wrist.  Try one of these instead:
http://www.toolking.com/dewalt/view.asp?id=2378
"I believe that every individual is naturally entitled to do as he pleases with himself and the fruits of his labor, so far as it in no way interferes with any other men's rights."
Abraham Lincoln
wee beastie
  • Last login:October 06, 2003, 03:33:02 pm
« Reply #2 on: June 02, 2003, 01:53:49 pm »
Looks like that one will break your wrist too if you don't have a drill press.  I could be wrong though.
I think you want a step bit.  It looks like a cone with ridges on it.  I believe that bob roberts sells them.
paigeoliver
  • Awesome face!
« Reply #3 on: June 02, 2003, 02:25:27 pm »
I have used one like that before. It worked, but it burned out after only two holes.
mj147
  • Last login:November 10, 2024, 08:04:14 pm
« Reply #4 on: June 02, 2003, 02:44:47 pm »
For my metal CP I just used a cheapo Home Depot Hole saw, I ended drilling about 14 button holes with a cordless drill without a problem.
mj147
Warborg
  • Last login:September 26, 2025, 07:26:44 am
  • Personal text? Nah...
« Reply #5 on: June 02, 2003, 03:02:10 pm »
You are wrong...   ;D
AlanS17
    • AlanS17
« Reply #6 on: June 02, 2003, 03:12:45 pm »
Any fine tooth hole saw from the local hardware store should put a hole in it. They sell hole saws specifically for drilling into metal. Plus make sure your pilot bit can actually burrow through the metal, too. If your pilot bit can't dent it then you'll never get down to the saw to cut it.
If your pilot bit keeps running around on the surface before going in you may want to start with a smaller starter hole using a standard metal bit. Make something like a 1/8 inch hole. That way you're sure it's centered.
Warborg
« Reply #7 on: June 02, 2003, 04:07:26 pm »
I just marked the center of where the hole was supposed to be, and then used a centerpunch to put a small divit for the pilot bit to grab onto...
locash
  • Got cash?
« Reply #8 on: June 02, 2003, 04:34:20 pm »
It can be pretty easy to burn out a hole saw while cutting metal.  If it heats up too much, it will lose its temper and get dull really quick.  Try keeping the rpms down on the drill and cutting a little at a time and/or using water or oil as a lubricant.  What ever you do to keep the blade cool will add to the life of the saw.
Warborg is on the money regarding the centerpunch.  It's the way to go to keep the pilot from wandering.
« Last Edit: June 02, 2003, 04:36:30 pm by locash »
Abraham Lincoln
