Author Topic: Best NES emulator for arcade cab??  (Read 1355 times)
arcadecab
  • Last login:September 26, 2007, 06:17:06 pm
« on: June 02, 2003, 11:05:32 am »
I am currently using Nesticle.  Are there any better emulators out there for NES??  How about for an arcade cab?
I am currently have a couple problems with Nesticle--
1)  I cant save the remapping of buttons to those that I want to use.
2)  I cant get the snapshot function to work properly--simply says cant save.
3)  Have to exit using the file menu--no one button exit key.
Thanks.
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
Re:Best NES emulator for arcade cab??
« Reply #1 on: June 02, 2003, 04:27:49 pm »
I tested a bunch of them and the one I ended up using
was VirtuaNes, I use it with a command line wrapper
in my custom front end. It has a GUI but I don't use it,
I don't believe it supports screenshots though. I run it on a P3- 850 the emulation speed is smooth and the sound is good.
                                  Slug54
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #2 on: June 02, 2003, 06:21:45 pm »
I use Virtual Nes also. It's very configurable.
colonelsnow
  • Last login:July 13, 2022, 07:56:26 am
« Reply #3 on: June 02, 2003, 06:32:53 pm »
Can anyone figure out its crazy snap shot naming methodology? I am trying to set it up for the rename function in Mamewah.
