Author Topic: Centipede Mini Restoration  (Read 46410 times)
SirPeale
  • Green Mountain Man
« on: May 29, 2008, 11:24:05 pm »
I picked this cab up in a lot of ten about two months ago.  The rest are in storage, but I thought I'd pick away at this one a bit at a time.
Vacuumed it out a couple days ago.  It was filled with mouse nests.  Gross.
Replaced a couple of the T nuts on the bottom with new leveler mounting plates, as well as the levelers.  All of them had holes thru them.
The power cord had its end torn right off.  I took a PC power cord, cut off the end and crimped on new Molex pins.  Good as new.
Next I thought I'd tackle the power distribution block.  Taking cues from BrentRadio's restorations, I disassembled it.  Scrubbed as much rust as I could from it.  I've masked off the original labels, and tomorrow I'll paint it brass.
SirPeale
Re: Centipede Mini Restoration
« Reply #1 on: May 30, 2008, 12:33:29 pm »
Cleaned the power distribution block a ton.  And reassembled.
Before and after shots.  It's good, but it could be better.  Still...I'm happy with it.
WunderCade
« Reply #2 on: May 30, 2008, 01:06:19 pm »
Did you just dust it off with a brush or did you disassemble it and detail it?
Also, in your first post....no pic of the cab??
SirPeale
« Reply #3 on: May 30, 2008, 02:17:27 pm »
Did you read or just skim?
I haven't taken one yet.  I've got ten other cabs I still have to take pictures of.  Don't worry, I'll take one eventually.
WunderCade
« Reply #4 on: May 30, 2008, 03:48:42 pm »
Oops!  :-[ I skimmed.  ;D
Anyways....nice job indeed.
SirPeale
« Reply #5 on: May 31, 2008, 11:15:54 am »
I've had problems with the board since day one.  I'd cleaned the legs on the ROMs before because they were heavily oxidized, but it only helped a bit.
Last night I took my soldering iron to the board and resoldered every socket on there, as well as any component that connected to ground.
Today I fired it up, and it still comes up with errors, but at least I can get it into test all the time now.  Comes up with ROM errors 2 and 4.
SirPeale
« Reply #6 on: August 07, 2008, 12:47:29 pm »
Oh  hey...picture...
« Reply #7 on: August 07, 2008, 12:59:14 pm »
That one has a good monitor-cab ratio.  Must be top heavy.
I'm looking forward to seeing what you do with the coin doors.   ;D
Level42
« Reply #8 on: August 07, 2008, 01:03:32 pm »
Nice work on the power brick, but shouldn't you replace the Big Blue ?
And don't you have a bit better resolution picture of the cab ?  Please ? :D
SirPeale
« Reply #9 on: August 07, 2008, 01:15:12 pm »
I'll replace it eventually.  Right now it's doing it's job.  Money is tight, and I've been funding cab purchases with store sales.  Sales have been slow lately, so that's why there have been no updates.  What it really needs is boardwork.  I want to replace all the caps, but more importantly either I have a bad socket or a bad ROM.
Yes, I have a hi-res photo, but it's huge.  That's why I resized it.
I've already pulled the coin door.  Most of the old coating came off in one big sheet.  The rust just tunneled under it.  Regrettably there was a tube lock on the bottom, and it was locked with no key.  I crowbared it.  Didn't want to, but I wanted to get to work on it and stop screwing around.
The last of the coating didn't want to come off easily with a wire wheel, so I'm going to do some chemical persuasion next.
« Reply #10 on: August 07, 2008, 01:49:06 pm »
I was at Harbor Freight the other day for 20 minutes staring at the sandblasting cabinets... so tempting it's not even funny.
SirPeale
« Reply #11 on: August 07, 2008, 01:57:54 pm »
If I had a place to use/store it I'd have built one a long time ago.  Living in a two bedroom apartment my choices are unfortunately limited.
« Reply #12 on: August 07, 2008, 02:04:44 pm »
I bet we could design one for occasional use that's easy to take apart and store.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #13 on: August 07, 2008, 03:44:42 pm »
Coin Door: Lots of sanding and spray paint = Will look new
« Last Edit: August 07, 2008, 05:09:56 pm by RayB »
NO MORE!!
SirPeale
« Reply #14 on: August 07, 2008, 04:47:28 pm »
Why replace the coin door? Look up my Centi mini thread. Lots of sanding and spray paint = Looks New
Who's replacing the coin door?  We're talking about replacing Big Blue.
RayB
  • There's my post
    • RayB.com
« Reply #15 on: August 07, 2008, 05:10:25 pm »
Saw Chad's post, saw your reply. Level42's was not noticed. Strange. I must have had him on Ignore. (Just Kidding!!!!)
NO MORE!!
Level42
« Reply #16 on: August 07, 2008, 05:19:41 pm »
Hehehehe, must be your spam filter...  :laugh2:
SirPeale
« Reply #17 on: August 07, 2008, 07:28:50 pm »
I'd have to worry about the compressor too.  Until I get a "real" workshop this is on a back-burner.
I've looked before in the area for people that sand/bead blast, but didn't find anyone.  I should ask again.  Concentrate on body shops this time.  I hear they use them a lot.
« Reply #18 on: August 07, 2008, 08:54:05 pm »
I have a compressor I haven't learned to use yet and a lot of stuff I could use a sandblaster on.    It's worth thinking about and you'd be able to box stuff up for me to blast in a batch.  If we could come up with a design that allows us to take it apart for storage it would be easy to build two and you just sit on yours until you have a compressor.  Or build it later.
SirPeale
« Reply #19 on: August 07, 2008, 09:01:20 pm »
If you weren't so damn far away I'd consider it.
SirPeale
« Reply #20 on: August 10, 2008, 07:39:07 pm »
Actually worked on this quite a bit today.  Pulled the harness out and monitor, sanded the heck out of the bottom of the cab, vacuumed and wiped down everything.  Started wire wheeling off the bezel retainer rust to repaint.
Then I pulled the board to clean the heck out of the ROM legs.  Thought (hoped) that this problem might be solved by dirty legs.  It's been reporting ROMs 2 and 4 as bad.
When I pulled 2 I found that one of the legs was gone entirely!  I was really excited.  I soldered on a cap leg I cut off from when I did cap kit.  Little change - now the P1 and P2 start buttons light up, but nothing else seems to be different.  I have to bite the bullet and get new ROMs.  Sucks they're so expensive.
SirPeale
« Reply #21 on: August 17, 2008, 08:26:39 pm »
I've been scrubbing the heck out of the coin door to get the old coating and the rust off.  I wish there was a sand blaster in this area, this is a big pain.
« Reply #22 on: August 18, 2008, 07:53:20 am »
Any chance of getting just a sandblaster?  I think Sears carries them cheap, no cabinet, just put the door against a rock and blast it.
SirPeale
« Reply #23 on: August 18, 2008, 08:40:33 am »
Also no compressor to drive the sandblaster.  And the fact that I live in the downtown area, I don't really have a place to do that outside of a cabinet.
I'd be fine taking it somewhere...IF there was somewhere to take it.
« Reply #24 on: August 18, 2008, 09:00:42 am »
There has to be an easier solution to this.  Chemical stripping?
« Reply #25 on: August 18, 2008, 09:16:57 am »
no powder coaters in the area?  they always have a sandblaster.  they could even just powder coat the door for you
SirPeale
« Reply #26 on: August 18, 2008, 09:41:25 am »
Stripping just removes the old coating.  I still have to deal with the rust.  Which isn't hard, it's just that there are all these impossible to get to area with my wire wheel.  Likely I'll just do it with sandpaper by hand.
Not that I'm aware of, or I would have gone that route.
« Reply #27 on: August 18, 2008, 11:20:19 am »
There are chemical strippers for rust too.
WunderCade
« Reply #28 on: August 18, 2008, 12:05:37 pm »
If you have a compressor, the sandblasting attachment is only 12 bucks at HD.
SirPeale
« Reply #29 on: August 18, 2008, 01:19:13 pm »
I don't.  Wish I did.
They don't do nearly as good a job as an abrasive, IMO.
RayB
  • There's my post
    • RayB.com
« Reply #30 on: August 18, 2008, 07:27:34 pm »
I just used an ordinary Mouse sander. Wasn't 100% down to the steel either. So long as it was smooth and no rust, it was ready for spraying.
(And results look like it's NEW!)
« Last Edit: August 19, 2008, 11:39:25 am by RayB »
NO MORE!!
« Reply #31 on: August 18, 2008, 08:10:42 pm »
No, but they do the first 85% of the work for you.  Then you finish with an abrasive.
« Reply #32 on: August 18, 2008, 08:15:59 pm »
if you are ok with shipping, I know the owner of Powder Barons (a local PC'er) and I could get you a great deal, he'll blast and coat it whatever color you want
http://www.powderbarons.com
just email him and tell them 3fastperformance referred you
« Reply #33 on: August 18, 2008, 08:49:11 pm »
Holy snot that guy's work is pretty.
Wade
  • Last login:December 01, 2025, 08:21:17 am
  • 80's Child
    • Wade's Gameroom
« Reply #34 on: August 19, 2008, 04:54:08 pm »
There are powder coaters in practically every city.  IMO it's not worth it for most arcade parts though.  You'll spend a lot more money because you are paying someone else the labor to blast the part and then to coat it.  Typically you'd spend $25-50 for one thing like a coin door.  Not worth it at all IMO.  Besides, a good $5 can of Rustoleum spraypaint looks just as good, if not better in most cases.  And in a home environment, the extra durability that powder coating sometimes provides is not really a concern.
All just my opinion of course.  I don't see anything wrong with powder coating, I just think it's wasted effort and expense on video games.
Wade
SirPeale
« Reply #35 on: August 19, 2008, 05:02:26 pm »
I guess it depends on the powder coater.  I've heard insane prices of like $75 to strip and recoat a door.  I've also heard of dudes that do it dirt cheap.  I'd at least check things out - IF there were guys that did it in my area.
RayB
  • There's my post
    • RayB.com
« Reply #36 on: August 19, 2008, 08:45:58 pm »
The way to get it done cheap is to have the parts slipped in with other parts being done of the same color, and the guy gets paid cash. Know what I mean?
NO MORE!!
« Reply #37 on: August 20, 2008, 05:47:46 pm »
3fast sends alot of business his way; cant hurt to drop an email, thats all Im sayin. If you have a buncha stuff you want done at the same time and the same color; even better for you.
I wouldn't suggest him if I hadn't used his service before. Just trying to help out a fellow BYOAC'er
« Reply #38 on: August 20, 2008, 08:56:21 pm »
Thought about this some today... while not quite a full stripper, how about a powerwasher?
Wade
  • 80's Child
    • Wade's Gameroom
« Reply #39 on: August 21, 2008, 04:59:46 pm »
Peale, where do you live?  IF you really want powdercoating, I'd bet there's a powdercoater somewhere nearby.  You might want to call some body shops or car/truck accessory places.  There are tons of guys that do this kind of work, especially since it can be done with minimal tools.  Find someone who is into classic cars, hotrods, or import sports cars.  They will probably know someone who does it.  My city is only 50,000 and I have run into several powder coaters before, and could probably find a dozen if I really looked.
Wade
