Author Topic: Monitor Distortion  (Read 1621 times)
davido
  • Last login:June 23, 2008, 10:12:32 pm
Monitor Distortion
« on: May 29, 2008, 09:43:41 pm »
First time on site, not sure if this is how to post a question. Sorry. I have a "std." arcade monitor. I have noticed a small (1" or so) section along the top and bottom of the monitor that have an s-shaped squiggle. The rest of the screen is ok. I've checked the voltage at the power supply, which was 5.3 V and -4.9 V. I've switched the motherboard with other jamma ready games and no change. Would this be a monitor chassis issue? Thanks, David
Ummon
  • Trade Count: (+13)
Re: Monitor Distortion
« Reply #1 on: May 30, 2008, 05:54:53 pm »
Look up the list. You'll see what you need to add here.
Yo. Chocolate.
Stephen Hawking
grantspain
« Reply #2 on: May 30, 2008, 06:51:04 pm »
start by adjusting the horizontal phase/hold/frequency(however it is noted on your chassis)
davido
« Reply #3 on: June 23, 2008, 09:53:48 pm »
davido
« Reply #4 on: June 23, 2008, 09:54:20 pm »
ok thanks, i'll try that.
