Author Topic: tv tubes  (Read 2254 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
tv tubes
« on: May 25, 2008, 01:04:48 pm »
are orion tubes any good to use as arcade monitor i have a 25 inch zenith tube that came from a well monitor but the picture is fuzzy and my we ya chassis is new
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: tv tubes
« Reply #1 on: May 25, 2008, 08:02:32 pm »
if it fits , USE it .
the mounting tabs may be reversed,  thus requiring spacers .
pin out should be the same
qrz
alienware32
Re: tv tubes
« Reply #2 on: May 25, 2008, 09:21:39 pm »
i used the orion tube out of a 27 inch tv that was going bad it is a perfect match it eliminate the blooming problem i was experiencing zenith tubes are crap
Zebidee
  • Last login:Yesterday at 11:25:34 pm
Re: tv tubes
« Reply #3 on: May 26, 2008, 06:51:32 am »
Did I hear someone say 'yoke impedance'?
You should measure the new tube's yoke impedance  with an ohmmeter first, and try to use a tube that has similar yoke impedances to the original tube's yoke.  Unless are swapping yokes as well?
If you are comfortable about swapping yokes, then I'm sure that I won't have to mention 'convergence' ...
Anyway, it seems that you have been lucky enough that the replacement tube actually works.
Fuzzy picture is usually a symptom of poor convergence and/or or a yoke that isn't spaced properly (ie, the triangular rubber feet near the back of the tube).  Actually, the two things are related.
Many sensible people avoid convergence adjustments as fiddling with it is very time-consuming, frustrating and not necessarily fruitful.  I wish you good luck and a cool hand if you choose that path.
Sooo, having said all of that, if the tube looks like sh1t on your new chassis then I suggest that you try a different tube.  Zenith tubes are indeed often crap, but Orion tubes aren't necessarily a great improvement.
alienware32
Re: tv tubes
« Reply #4 on: May 26, 2008, 08:42:27 am »
the last tube out of the orion tv is a perfect match the picture is perfect
Zebidee
Re: tv tubes
« Reply #5 on: May 26, 2008, 11:13:27 am »
The convergence can be wildly different between different tubes.
alienware32
Re: tv tubes
« Reply #6 on: May 26, 2008, 12:32:55 pm »
your right but i think orion tubes are a good match
Zebidee
Re: tv tubes
« Reply #7 on: May 26, 2008, 09:20:52 pm »
Yeah, seems to be the case.  Looks like you'll have to toy with the yoke position and maybe the three (or maybe four) convergence rings.  Not for the faint hearted - do some research on CRT convergence theory before you try this.
You might find it easier to find another tube that matches rather than spending many hours attempting to get the convergence 95% right.  It depends upon how much time you have and your tolerance for frustration I think.
Ummon
  • Trade Count: (+13)
Re: tv tubes
« Reply #8 on: May 28, 2008, 06:16:39 pm »
Yeah, this can be frustrating. I did this without a mirror and it's pretty decent, but it took me a couple/few tries and a couple hours I think. I had NO idea what ring did what, though. I just eye-balled it.
Yo. Chocolate.
Stephen Hawking
