Author Topic: Rebirth Marquee Rough Draft  (Read 3562 times)
Witchboard
  • Last login:January 05, 2022, 09:09:24 pm
    • Oklahoma Coin-Operated Collectors
« on: May 22, 2008, 11:46:24 pm »
Finally working on my fathers bartop artwork.  Rough draft, a lot of cleanup still needed.  Thought I would get opinions on possible improvements.
  • Last login:December 16, 2025, 04:07:15 pm
Re: Rebirth Marquee Rough Draft
« Reply #1 on: May 23, 2008, 01:09:56 am »
I think the text could be bigger, and the letters could use some embossing to make them more 3d. It looks like one of your goals was to make the I centered under the Galaga ship and that may be difficult with larger text, but I think larger text would look better.
Witchboard
« Reply #2 on: May 23, 2008, 07:59:56 am »
When you say larger, do you mean stretch it the length of the marquee?  It pretty much can't go any lower as it will be covered by the marquee retainer.
unclet
« Reply #3 on: May 23, 2008, 08:57:55 am »
Instead of having the "Rebirth" text displayed straight, why not have it curved a bit to follow the same curve as the bottom part of the galaga bird thing.    If you do this then the "R" and "H" characters in "rebirth" can be made larger to fill out the marquee more.
Hope that made sense....
(EDIT)
Something like this ....... but you would have the galaga bird thing covering the tops of the  "B I R" characters a bit.   I know I used a crappy font, but you can make it look a lot better using 3D effects and lighting effects ...... I just wanted to show you what I was visualizing.
« Last Edit: May 23, 2008, 09:09:38 am by unclet »
Witchboard
« Reply #4 on: May 23, 2008, 06:56:28 pm »
I don't have Illustrator, but I'll see what I can do.  Thanks.
Something more similar to the below?
« Last Edit: May 23, 2008, 11:01:09 pm by Witchboard »
ivwshane
    • My first mame cab! (WIP)
« Reply #5 on: May 25, 2008, 04:01:01 pm »
Looking better.
What about doing what you did on the last one but take the top of "rebirth" and stretch it out a bit more so it's not quite as slanted as it is now and it fills up just a little more of the marquee?
Witchboard
« Reply #6 on: May 25, 2008, 05:41:44 pm »
Hmmm... it seems I'm getting the general concensus that the vertical distortion I was going for doesn't look good.  I've made the text larger, removed the distortion and gave it a little gradient just to play around.
unclet
« Reply #7 on: May 25, 2008, 06:31:52 pm »
Awesome   :applaud: :applaud:
This is what I was envisioning .... you even did a good job of covering the BIR letters with the bird-like thing ....
« Last Edit: May 25, 2008, 06:33:26 pm by unclet »
ivwshane
« Reply #8 on: May 25, 2008, 07:51:39 pm »
I like the one without shading. Do you have one that is slightly angled (just not as much as before)?
Witchboard
« Reply #9 on: May 26, 2008, 02:01:58 am »
Yes, I can add in some slight angle.  I decided to angle it the other way to see what it looked like.  I haven't decided on text colors yet, just been playing.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #10 on: May 26, 2008, 10:06:49 am »
Oooooo, I like.
ivwshane
« Reply #11 on: May 26, 2008, 10:45:59 pm »
I think it would look good angled the other way.
Witchboard
« Reply #12 on: May 27, 2008, 12:11:43 am »
I don't care for it angled the other way.  The text covers all of the wing-tip feathers, and I want those visible.  I can play with the font size and see how it turns out.
I pulled it in a little where the angle isn't so large.  I think it's pretty much where I like it.  I'm going to start cleaning it up and working on a color scheme.  Any input on text color?
« Last Edit: May 27, 2008, 11:26:36 pm by Witchboard »
