Author Topic: Anyone sell this type of joystick mounting plates?  (Read 1516 times)
Lilwolf
« on: May 16, 2008, 08:13:54 pm »
I have 2 ls-30 rotary joysticks (ikari).  I am about to put them into a new control panel, but I HATED building the last ones (pain in the ass).
Anyone know if anyone sells a mounting plate that fits these?  I believe they have the standard japanese joystick screw holes.
thanks
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Anyone sell this type of joystick mounting plates?
« Reply #1 on: May 19, 2008, 06:47:17 pm »
Total guess, assuming the ls-30 are like Seimitsu's ls-32:
Lizardlick has a couple plates for the ls-32/ls40 sticks, almost all the way on the bottom of the page.  Note I have no idea if they will work or not.  Hmm, dimensions of the mounting holes at slagcoin; without pull my sticks out, I'd guess the ls-30s will fit, using its long narrow mounting holes to match the 85mmx40mm, but you should measure first. ;)  (If I'm wrong, maybe the sanwa plates will work?)
FWIW, I used oscar's mounting plates, but they aren't around anymore. :'(  It used the wide holes on the ls-30, which match the happs/u360 holes (2.6"x3").
Robin
Knowledge is Power
