Author Topic: What is this thing called?  (Read 1361 times)
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
« on: May 14, 2008, 07:33:48 pm »
Does anyone know the proper name for this outlet/switch/fuse combination?
Also, is there any way I could connect one of these to this:
or even connect it to a regular PC power supply?
Steve B.
  • Last login:July 22, 2017, 10:32:41 am
Re: What is this thing called?
« Reply #1 on: May 14, 2008, 11:25:39 pm »
It's called a "Power Entry Module". Do a search at Mouser or Digikey and you'll find several styles. The module will have bare terminals on the back which feeds the equipment. I would have it feed a standard AC outlet where you can plug in your computer.
EndTwist
  • Arg.
« Reply #2 on: May 15, 2008, 12:22:23 am »
Perfect, thanks! I have a nice rectangular gap in the back of the cab where this was, so I wanted to fill it in with a new one of these (plus, it is actually pretty convenient).
I could basically wire this up to a standard AC outlet on the inside, and plug whatever I need into it?
TOK
  • The Game Always Wins
« Reply #3 on: May 15, 2008, 05:55:58 am »
The Craftsman power switch works great. I guess you've have to cut the cord to wire it to the inside of your power entry module, but the switching aspect of it works fine for a cab. I've been using one for over a year.
