Author Topic: Small project: mame-ing my Capcom Impress  (Read 2431 times)
Ummon
  • Trade Count: (+13)
« on: May 14, 2008, 01:47:40 am »
Well, I've been doing some small wiring on my Impress. First up was the controls. I didn't want to re-wire everything so am using the existing wiring hooked up to a GPwiz. I'm having some issue here, as Windows sees the unit but keypresses aren't registered.
« Last Edit: May 14, 2008, 01:51:38 am by Ummon »
Yo. Chocolate.
Stephen Hawking
Ummon
Re: Small project: mame-ing my Capcom Impress
« Reply #1 on: May 14, 2008, 01:51:30 am »
Just for fun, here's a picture of the monitor chassis. I was waiting on getting some torx bits to get into these parts, and I'm glad I did. Whereas initially I didn't think it was necessary, I found the chassis wasn't secured. It was screwed in - the screw lower-right - but there's a flange on the left the chassis fits under, and it was on top of it. The pcb had lifted or bent a little by the screw.
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #2 on: May 14, 2008, 01:56:24 am »
Next I'm wiring the monitor to the VGA port of the PC. I have this neat little deal that has a six-pin header on one end and a VGA port on the other.
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #3 on: May 14, 2008, 02:00:18 am »
And here are the rest.
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #4 on: May 14, 2008, 02:05:33 am »
Now, I'm having some trouble with the video. The color is great. But the image is garbled. JAMMA is composite sync....from the board, right? But from the PC it's not. I think this is where my problem is, yes?
*the first image is with the sync wire attached to the V pin; the second image is with the sync wire attached to the H/C pin. Also, I forgot to mention that I'm using Advancemame here on auto.
« Last Edit: May 14, 2008, 02:40:10 am by Ummon »
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #5 on: May 14, 2008, 02:39:05 am »
Here is a picture using Mame32 and soft15 - Gyruss @ 352x256 - and with the sync wire on V.
Yo. Chocolate.
Stephen Hawking
Paladin
  • Mmmm llamaburgers!
« Reply #6 on: May 14, 2008, 10:09:15 am »
I'm guessing your keypresses aren't working because you don't have a ground wire going to the encoder.  At least that's what it looks like in the picture.
Ummon
« Reply #7 on: May 14, 2008, 03:48:38 pm »
Funny you say that, heh. I thought this was the case and am waiting an answer in 'Main' because I don't know what ground(s) to use.
« Last Edit: May 14, 2008, 09:45:12 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
