January 22, 2026, 04:46:18 am
I have the 4.1 promedia and have the same problem that jhabers has....anyone know how to fix this??$68 for the 2.1 is a very nice deal. It's a great set.
Quote from: Moose13 on May 14, 2008, 08:55:03 amI have the 4.1 promedia and have the same problem that jhabers has....anyone know how to fix this??$68 for the 2.1 is a very nice deal. It's a great set.Usually, it's a dirty pot. Sometimes they can come from the factory with what I'm suspecting is some kind of fine grit from....well anywhere. Doesn't take much. The common wisdom says to crank the pot several times. You also might try spraying some electrical board cleaner in the pot socket when the system is off.
