Author Topic: Namco System 12 Question  (Read 1199 times)
moloch
  • Last login:June 29, 2022, 06:22:19 pm
  • I'm an ill'llama!
« on: May 10, 2008, 12:01:02 pm »
The cabinet that I picked up recently came with a Tekken 3 board. Does anyone know how to get a system 12 board to enter the configuration screen.
According to the KLOV:
This was the first game to use Namco's System 12 board. The PCB does not have any DIP switches. Instead, a game configuration screen appears after pressing the Test button on the board set.
I cannot find this "button" anywhere.
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
Re: Namco System 12 Question
« Reply #1 on: May 10, 2008, 01:20:12 pm »
Do you have the Jamma pinout for the board?
If so there should be a wire connection for a test button, you can wire one yourself for testing purposes.
There are three kinds of people in the world those that can count and those that can't.
moloch
  • I'm an ill'llama!
« Reply #2 on: May 10, 2008, 09:14:13 pm »
Those wires were missing from the harness, so I put some bare wires in there and a switch and guess what it worked. Thanks. Now when I play 2 player it will not just be 1 match. :applaud: :applaud: :applaud:
