Author Topic: Other emulaters compatible with arcadevga?  (Read 934 times)
Jox43w
  • Last login:May 22, 2009, 05:55:28 am
« on: May 09, 2008, 04:33:30 pm »
Can i use any other emus with the arcadevga like snes megadrive? Or evern dreamcast?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Other emulaters compatible with arcadevga?
« Reply #1 on: May 09, 2008, 05:56:17 pm »
All of them if you can configure the resolution to output low enough
NO MORE!!
ahofle
    • Arcade Ambience Project
« Reply #2 on: May 09, 2008, 06:00:44 pm »
I have not found an emulator that doesn't work with the AVGA.  Remember, you can always use 640x480 interlaced worst case, so anything that supports 640x480 will be fine.  If you have a multisync arcade monitor, you can go even higher (640x480 progressive, 800x600 and 1024x768 in some cases).
