Author Topic: MagicEngine update (attn: ArcadeVGA owners)  (Read 2961 times)
Minwah
    • MAMEWAH
« on: May 08, 2008, 12:20:31 pm »
I haven't tried this yet (will do tonight), but MagicEngine has been updated, and it should now support ArcadeVGA resolutions!  :)
Note that v1.1.0 is the big update, but in the forum is bugfix v1.1.1
FrizzleFried
    • Idaho Garagecade
Re: MagicEngine update (attn: ArcadeVGA owners)
« Reply #1 on: May 08, 2008, 01:18:55 pm »
May I ask what MagicEngine is?
joebells
  • Last login:January 11, 2009, 07:57:45 pm
« Reply #2 on: May 08, 2008, 01:22:29 pm »
its an engine that is magical, requires no fuel, will run forever. Or maybe its a turbographx 16 emulator(might emulate a few other systems also not sure I just use it for turbographx f16
Twin-X
  • Last login:April 26, 2018, 05:59:44 pm
  • Yes this avatar was stolen too!!!
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #4 on: May 08, 2008, 04:01:40 pm »
I just don't understand how they can get away with charging for an emulator...  Paying for an emulator just doesn't make any sense.  Now supporting an emulator developer by giving a donation is fine, but I don't agree with charging for an emulator.
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #5 on: May 08, 2008, 06:09:00 pm »
MagicEngine has always been a VERY exceptional emulator.  I payed for it many years ago and it was worth every single penny.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #6 on: May 08, 2008, 11:13:55 pm »
I've used it off and on for years, but not much. I can't find an auto frame skip. Any clues?
I think I have .99 or 1.0 on my cab, not sure.
I can set it to skip X amount of frames, but haven't found an auto skip. It runs either too slow or too fast depending on the setting.
Minwah
    • MAMEWAH
« Reply #7 on: May 12, 2008, 05:14:53 am »
Sorry I forgot to paste the link in my original post.
I have to second that it is a very good emulator. Still haven't tried it but low res. support should be the finishing touch really.
Ummon
  • Trade Count: (+13)
« Reply #8 on: May 12, 2008, 04:24:53 pm »
I see they're all anime-themed. Did they even exist in Japanese arcades?
Yo. Chocolate.
Stephen Hawking
Minwah
    • MAMEWAH
« Reply #9 on: May 13, 2008, 06:41:29 am »
Don't know if any else has tried this but unfortunately while low-res modes are listed, I can't get them to work (PCE crashes).  Will reoprt at the Magic Engine forum...
Edit: someone else has it working OK, so gonna play around with the pce.ini file...
« Last Edit: May 13, 2008, 08:58:19 am by Minwah »
Lilwolf
« Reply #10 on: May 13, 2008, 08:15:35 am »
someone should also give it a try on a soft15khz setup.
btw, I thought this was a pay emulator.  Did they change?
Minwah
    • MAMEWAH
« Reply #11 on: May 13, 2008, 08:59:38 am »
You can download a demo, but I think it is limited to 5 mins (although you can use save states). It costs 15 Euro's to register.
northerngames
  • Trade Count: (+18)
« Reply #12 on: May 13, 2008, 03:42:30 pm »
hugo runs fine and is free
Minwah
    • MAMEWAH
« Reply #13 on: May 15, 2008, 09:03:21 am »
I had never heard of that one.
Minwah
    • MAMEWAH
« Reply #14 on: May 15, 2008, 09:04:48 am »
OK got it working! Now using v1.1.2.  I think the problem was I had an aspect ratio setting wrong, it should be set to 0.  Another thing is that I can't get the GUI to run low-res, but that doesn't really matter, the games look great :)
Ginsu Victim
« Reply #15 on: May 15, 2008, 09:54:39 am »
Anyone?
Minwah
    • MAMEWAH
« Reply #16 on: May 15, 2008, 12:07:26 pm »
Anyone?
Sorry, didn't see your post before...
There is an option for frameskip in pce.ini...but I don't think there is auto frameskip.  I would just turn it off (set to 0).
Ginsu Victim
« Reply #17 on: May 15, 2008, 01:47:22 pm »
Yeah....not exactly possible. I run it on a 733mhz and it's not even close to playable at that. At 1 frame skip, it's still slow, and at 2 frame skip, it's mostly good, but can be too fast in spots.
I haven't tried Hugo in years. I'll have to revisit that.
northerngames
« Reply #18 on: May 16, 2008, 08:32:10 am »
yeah it worked great on xbox so I tried it with mamewah also and it works flawless.
http://www.emulator-zone.com/doc.php/pcengine/hugo.html
it requires the GTK+ in order to run though becuase that is what it was based off of.
http://www.gtk.org/download.html
« Last Edit: May 16, 2008, 08:38:22 am by northerngames »
