Author Topic: i am new to all arcade stuff and need help on SpyStyle boot CD  (Read 1621 times)
jd12586
  • Last login:May 05, 2008, 03:45:11 am
hi i try SpyStyle boot CD like 15 time and i can this error missing option device_video_p/h/vclock. i am new to all of this things. i using a intel(r) celeron(r) cpu 2.40ghz memory 512 and using a pc monitor 21" intergraph model # 21sd100. thanks
tikbalang
  • Last login:May 07, 2013, 05:04:54 pm
    • MAME BootCD's for DOS
Re: i am new to all arcade stuff and need help on SpyStyle boot CD
« Reply #1 on: May 01, 2008, 09:24:51 am »
are you sure you're using spystyle's cd? that seems to be easymamecab cd. you need the pixel/vertical/horizontal clock values of your monitor. look it up in your manual. or use advcfg.exe and use default values for your monitor type. if you end up with a black screen just press enter and skip testing. test by playing a game in the emulator.
jd12586
« Reply #2 on: May 01, 2008, 04:11:32 pm »
yes i am using spystyle cd . i dont have the manual how can i use advcfg.exe?
tikbalang
« Reply #3 on: May 02, 2008, 06:48:52 am »
the manual has the answer.
to use advcfg, find it, go to where it is, and type its filename at the prompt.
