Author Topic: Buying a CRT TV from one of the 2... any suggestions?  (Read 2406 times)
nickynooch
  • Last login:August 29, 2020, 02:54:00 am
« on: April 30, 2008, 03:29:55 pm »
Anyone have any ideas on the TVs below?  Will it work ok in my cabinet?  Any way to see if it has the "save state" feature where one it turns off it remains on the same state as it was before you turned it off (so I can power off and on with a power strip and not have to configure stuff every time).  Probably using the smartstrip option.
any advice/help would be great!  Hard to find a CRT tube 27inch for this cheap and new (without having to pay shipping)!
Sansui 27 in. CRT SDTV model# DTV2760
http://www.sears.com/shc/s/p_10153_12605_05747267000P?vName=Computers+%26+Electronics&cName=Televisions&sName=Tube+TVs
or
RCA 27" Tube SDTV, 27F554T
http://www.walmart.com/catalog/product.do?product_id=9188630
-Nick
« Last Edit: April 30, 2008, 04:40:34 pm by nickynooch »
nipsmg
  • Last login:January 20, 2026, 10:46:56 am
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Possibly buying a Sansui 27 in. CRT TV model # DTV2760
« Reply #1 on: April 30, 2008, 03:58:22 pm »
I have a 27" sansui tube TV.
I don't know about THIS model,  but mine remebers the input, but not the power setting.
HOWEVER, if you hold down the power button, when you plug it back in, it turns on.  So if you're going to use this in a cabinet with something like the smartstrip, then you should be good to go, if it has the same feature.  Just tape the button down (or if you take it out of the case, use something to keep the button on the circuit board held down.  No problems! :)
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Buying a CRT TV from one of the 2... any suggestions?
« Reply #2 on: April 30, 2008, 11:03:56 pm »
just make sure neither is made in China .
don't know about Sansui , but RCA has had some models mfg in China that are J U N K !!
let the buyer beware
qrz
nickynooch
« Reply #3 on: May 01, 2008, 02:36:15 pm »
Yeah, after reading more and more about RCA I think I am back to square one.  I guess I'll start scoping pawn shops as the "power-return" feature is huge for me, and it seems like it's very hard to find out if that is included without testing it yourself.
From what I hear on these boards it seems like most Toshiba's have the power return feature.
qrz
« Reply #4 on: May 01, 2008, 06:16:49 pm »
many newer sets can be set to pwr up upon connection to AC mains via menu setting.
those that can't ,can be made to do so with a simple circuit.  ;)
pm for details
qrz
