Author Topic: Need help identifying connector types and numbers, where to order, etc  (Read 2566 times)
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Back when I was working for an operator, I had all the stuff I needed to make harnesses at will.
Now that I no longer do, I don't have the items I need to repair and/or build harnesses.
My memory is *crap* these days.  I can't remember what these items in particular are.
First: monitor signal connector.  I've got a few of the housings, but I need the pins that go inside them.  What are both called?  Here: http://www.competitiveproducts.com/list.php?id=32 is where I got the housings, but the Trifurcon pins don't fit in there, or I'm doing it wrong.
Next: we called them "pinball connectors" at my former employ.  The type used to connect power connectors on pinballs.  I know they're IDC, but I need to know specifically what type.  There are too doggone many to wade thru.  I could use both male and female.
All help is appreciated!  I have a video connector that's currently on hold because I need the pins.
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
Housings:
MOLEX: KK® Crimp Terminal Housing, 0.156" Pitch
AMP: SL-156 SERIES, .156", NYLON
Female Contacts Molex: KK Series .156 (3.96mm) Trifurcon Crimp Terminals 08-50-0189
Jameco.com or mouser.com has them both... you can get them with or without a locking ramp... sometimes Jameco does not have the selection that mouser has cause there are so many options... ramp/ no ramp, keyed / not keyed and number of positions...etc.
« Last Edit: April 30, 2008, 11:39:56 am by RetroACTIVE »
Happy Gaming!
Ken Layton
  • Guru
  • Technician
The video connectors are Molex "K.K." series spaced .156 inch (Mouser Electronics numbers shown):
538-09-50-7061 6 pin housing
538-09-50-7031 3 pin housing
538-09-50-7101 10 pin housing
538-08-50-0106 normal pin for above housings
538-08-50-0189 trifurcon pin for above housing
As to "pinball connectors" most pinball manufacturers used a mix of AMP brand and/or Molex.
Typical on Williams system 11 are these AMP "MTA .156" IDC connectors:
571-6405999 9 pin IDC Orange 18 gauge
571-6406009 9 pin IDC Yellow 20 gauge
571-6406019 9 pin IDC Red 22 gauge
AMP colors their IDC connectors for a reason. Each color connector is designed to only accept a certain gauge of wire throughout the whole connector. The above are just examples.
SirPeale
I never could get the trifurcon pins to fit in that housing correctly.  Must be something I'm doing wrong.
As for the "pinball connectors" the ones I've dealt with have been a neutral color.  Later Williams pins had them, IE Star Trek, Red & Ted's Road Show, Terminator 2 and the like.   Are those the same as above?  And what are the male part numbers?
SirPeale
Also, they had a lot more than nine positions on them.  More like 24, IIRC.  Wish I still had some intact to reference by.
Ken Layton
  • Guru
  • Technician
I only used 9 pins as an example. They are made in other sizes.
Great Plains Electronics also sells connectors specific to pinball and video games.
SirPeale
I contacted my contact @ Betson New England (where they purchased those connectors).  I was surprised she still worked there, I thought she was retiring.
She told me that these connectors are from a company called Cinch.
http://www.cinch.com/index.cinch from a Google search
but I don't see these connectors on their site.
SirPeale
Called Cinch, they told me they have no idea what I'm talking about.
Though the ones @ Betson are $1.30 each, the shipping kills the deal.  Guess I'll have to put together an order.
SirPeale
I found a couple of the "pinball connectors" in an old toolbox.
I also found this @ Mouser: 571-6447526 but I'm not sure if it's the same thing.
SirPeale
I took a good close look at the connector I had and noted it said "ITW" on it.  Google brought me this:
http://www.itwpancon.com/
Those are it in their front page picture, now to narrow it down...
SirPeale
Thanks, Jim, for posting the link, and Ken for first suggesting it.  They had the male connectors I was looking for, but not the IDC female.  Probably because all pinheads insist on replacing the IDC connectors with the other style - they're more reliable.
I'll just get them from my old contact.  I have to place an order soon, anyway.
Ken Layton
  • Guru
  • Technician
Some of the machines people have brought to work on lately literally have had to have ALL the connectors (male and female) replaced due to corrosion or broken contacts.
Ken Layton
  • Guru
  • Technician
Bally "Special Forces".
