Author Topic: Need help with mame arcade setup and X arcade controls  (Read 1391 times)
huskyfan42
  • Last login:May 08, 2008, 03:16:13 pm
« on: April 26, 2008, 06:19:50 pm »
All of the controls seem to work fine in the test.
During a game the joystick works fine upward, left and right but it doesn't want to move downward.
So the pacman or ladybug etc... will let you take him all the way to the top and then left or right but it won't let you go back go back down toward the bottom of the maze.
Any suggestions?
Thanks Tom
« Last Edit: April 26, 2008, 07:14:53 pm by huskyfan42 »
severdhed
  • RIP Dinosaur Hippo
Re: Need help with mame arcade setup and X arcade controls
« Reply #1 on: April 26, 2008, 11:11:43 pm »
does the down arrow work outside of mame?  maybe it isn't mapped properly, or maybe one of the wires came off.  x-arcade has a test program you can download to make sure everything is working...
http://www.xgaming.com/service/joy-support.shtml#TEST
i'd start there
huskyfan42
« Reply #2 on: April 26, 2008, 11:54:46 pm »
The X arcade tank stick seems to work fine in the test mode.
Thank you for the response.
MiahXGaming
  • Last login:May 26, 2016, 02:42:21 pm
  • Legend
    • X-Arcade
« Reply #3 on: April 28, 2008, 11:05:40 am »
Delete the file "default.cfg" and try again. Otherwise change it in MAME manually:
http://www.xgaming.com/service/how-to-x-arcade-mame.shtml#configuration
