Author Topic: WG U5000 Still Dull  (Read 1831 times)
ToplessZ
  • Last login:December 08, 2018, 09:55:34 pm
WG U5000 Still Dull
« on: April 23, 2008, 05:05:56 pm »
Rick heres the part numbers you needed..
Tube  R-A63ADG25X
Yoke 9A3002-1
Im still having trouble with my U5000, Ive capped it, and replaced resistor 811.  The picture is just dull...  Any suggestions...
SirPeale
  • Green Mountain Man
Re: WG U5000 Still Dull
« Reply #1 on: April 23, 2008, 05:43:28 pm »
Hook it to a rejuvinator and test its output.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: April 23, 2008, 06:08:42 pm »
Test the tube on a rejuvenator. Is the tube a Zenith? If so throw it in the garbage.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #3 on: April 23, 2008, 08:14:11 pm »
i assume u changed c805,808 (2.2uF@200v) on the main pcb .
checked and/or replaced caps on the neck board . q501,502 can fail ( low gain )
the cathode emissions would have been my 1st test......
the biggest issue on Zenith crt's is intermittent hk shorts .
so what ,  just isolate the filaments and use it till it dies ........
there are far too many mfgr's producing junk these days .  :angry:
 pick a product , ANY product and one can find a person that will swear by it, and another that will swear AT it ...
qrz
ToplessZ
« Reply #4 on: April 24, 2008, 07:59:21 am »
havent changed Q501, 502.  Ill start looking to order those....
