Author Topic: Mame FE options  (Read 1468 times)
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
Mame FE options
« on: April 22, 2008, 03:35:09 pm »
Hello all,
I need a frontend for mame that runs well under xp, has an assignable button to flip menu from horizontal to vertical and back, and automatically displays a seperate list for the corresponding horizontal and vertical games.
Any takers??
Dexter
youki
  • Atomic Front End Creator
    • Atomic Front End
Re: Mame FE options
« Reply #1 on: April 22, 2008, 03:58:48 pm »
I take!
With Atomic :
You can not assign yet a button to flip menu from horizontal to vertical, but you can do a menu that shows :
Vertical games
Hortizontal games
And when you select vertical games , you enter on a new menu which is vertical.
Something for horizontal.
Or
you have an option to Automatically rotate the menu , in function of the last game launched.
ex :
you are in horizontal menu , you run Donkey kong (a vertical game) ,  you rotate your screen , you exit the game, now back on the menu , the menu is vertical.
Now you run a horizontal game ,  you rotate your screen, you exit the game, now bakc on the mneu, the menu is horizontal again.
but, you can do the same thing (automatically rotate) with Mala too , if you prefer.
loadman
    • MaLa
Re: Mame FE options
« Reply #2 on: April 22, 2008, 07:30:06 pm »
Indeed. Also with MaLa you can assign a key to change orientation or flip.
Dexter
Re: Mame FE options
« Reply #3 on: April 23, 2008, 04:21:12 pm »
Sounds like I'll be checking out Mala, thanks
