Author Topic: Does your cabinet fit through a standard door?  (Read 2652 times)
mattnb
  • Last login:April 11, 2009, 12:59:24 pm
« on: April 21, 2008, 09:44:28 pm »
I'm planning on using a 27" TV for my cab that I'm building this summer but I'm not so sure it will fit through a door. Anyone with 27" televisions have any input on this?
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
Re: Does your cabinet fit through a standard door?
« Reply #1 on: April 21, 2008, 09:56:37 pm »
a standard door can range in size.
the one we built is 31-1/2" wide without the CP, so it might fit thru a 2-8 width door, by removing the door, unless the door can open and hopefully not have to remove the door stops.
i guess a standard interior door width would be 2-4 to 2-8, but could be wider or narrower.
we could have made the cabinet a couple inches narrower and still fit the 27" tv.
Jdurg
« Reply #2 on: April 21, 2008, 10:25:01 pm »
The cab I'm building is going to be 28.5 inches wide since the doorways in my house are only 30 inches wide.  I have to make my CP separately and install it later.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
Minwah
    • MAMEWAH
« Reply #3 on: April 22, 2008, 04:41:33 am »
I made sure my cabinet was not too wide to fit through my doors, although it is quite tight in some of them!
Fozzy The Bear
  • Handbags at dawn in here!!!
« Reply #4 on: April 22, 2008, 05:00:53 am »
A standard interior door is 2 foot 6 inches by six foot six inches. A standard exterior door is 3 foot by six foot six inches.
Best Regards,
Julian (Fozzy The Bear)
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
« Reply #5 on: April 22, 2008, 08:10:50 am »
UA2 cabs needs to be taken apart into three pieces (but that is the reason they are designed that way).
Your screen name has been added to my frag list.
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #6 on: April 22, 2008, 08:23:16 am »
You can always remove the door from it's hinges to gain a couple extra inches - that's what I had to do (my cab has a 27" monitor).
Robots will kill you.
Arcade Addiction
Stub
  • Last login:July 08, 2024, 10:48:14 am
  • Sensory Overload
« Reply #7 on: April 22, 2008, 10:30:24 am »
I built in 3 pieces, ( well cp is not finished yet ) My top is 29.5". I can fit it if I take my door off the hinges, but the depth is several inches less so I can C it through most any doorway. Bottom is 28" no problem there.
TOK
  • The Game Always Wins
« Reply #8 on: April 22, 2008, 12:25:48 pm »
The two cabs I have in the main part of my house are conversions (a 25" Dynamo and a Bally Midway Rampage style cab) with fixed control panels. I have to take the door off the hinges and also remove the door trim to get them through. I've done it a few times, and it's no big deal once you try.
If you need to pop the trim, I recommend getting a painters tool. It looks like a scraper, but has a strong blade. Makes it easy to pry up trim without marking up the wood or paint, unlike a pry bar or screwdriver.
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
« Reply #9 on: April 22, 2008, 04:28:16 pm »
This is a 30" door and a 27" tv.  Have to take off the cp to do it tho.
Jdurg
« Reply #10 on: April 22, 2008, 11:46:32 pm »
Yeah, that's why I built my CP separately.  I want my cab to have a 25" monitor and my CP is about 37" wide.  Too wide to fit through a door so it is built separate and will attach to my cab once it's built.  On the bright side, building the CP let me learn about woodworking.
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
