Author Topic: Mala crashing  (Read 2665 times)
Trebeck
  • "The Arcade" - Build #4
Mala crashing
« on: April 21, 2008, 01:22:36 am »
Hey all,
I love Mala, but it's been crashing lately and I get these errors.  Any ideas?
2008/04/20  22:18:06.65   Error: Object Class: TTimer, Object Function: DisplayVideo, Exception Class: EListError, Exception Message: Der Index der Liste überschreitet das Maximum (6631)
2008/04/20  22:19:15.78   Error: Object Class: TPopupList, Object Function: FormClose, Exception Class: EAccessViolation, Exception Message: Zugriffsverletzung bei Adresse 005EE663 in Modul 'MaLa.exe'. Lesen von Adresse 00000014
2008/04/20  22:19:20.50   Error: Object Class: TPopupList, Object Function: FormClose, Exception Class: EAccessViolation, Exception Message: Zugriffsverletzung bei Adresse 005EE663 in Modul 'MaLa.exe'. Lesen von Adresse 00000014
2008/04/20  22:19:26.78   Error: Object Class: TApplication, Object Function: FormClose, Exception Class: EAccessViolation, Exception Message: Zugriffsverletzung bei Adresse 00411AB1 in Modul 'MaLa.exe'. Lesen von Adresse 00000001
Thanks for any help
-Beck
loadman
    • MaLa
Re: Mala crashing
« Reply #1 on: April 21, 2008, 05:25:00 am »
hmmmmm
What has happened since your last post at the end of this thread  ???
http://forum.arcadecontrols.com/index.php?topic=74768.msg774032#msg774032
From my experience this sort of error only occurs when it is upset about a certain type of video or pic .
What item or circumstance does it occur?
Try eliminating things,
In configure-gui-options you can turn of pics and/ or videos. If one on these stop it crashing then turn it back on and make note of what items it happens on etc
Good Luck  ;D
« Last Edit: April 21, 2008, 05:31:40 am by loadman »
Bloodwyn
  • Last login:October 17, 2020, 09:51:10 am
Re: Mala crashing
« Reply #2 on: April 21, 2008, 07:21:43 pm »
hmmmmm
Good Luck  ;D
I agree with Loadman. I had several consistant crashes. 1 of my crashes with pretty much the same errors as yours was due to a video (area51) that Mala did not like. It played fine in winamp, but Mala would crash every time I came to it in the list.
I also had a graphic that Mala did not like (Marquee screenshot). I just resized the graphic by 1 or 2 pixels and .. wala.. fixed.
I have a feeling that it has to do with the resolution of the image, rather than the fact that anything is corrupt.
Good Luke,
Bloodywn
Trebeck
Re: Mala crashing
« Reply #3 on: April 22, 2008, 11:23:26 am »
OK so there's really nothing specific in the log to tell me where it's at.  Well the graphic thing makes sence to me but I'll have to hunt down the offending graphic. Damn.  At least I know it's happening when NES is involved.  And I also think it's not a video preview because it crashes right away and I have the vids come on after 5 seconds.
Let the hunt begin.  Thanks you 2, I appreciate the help  :cheers:
-Beck
