Author Topic: Control Panel made out of Plexi or other clear material  (Read 2334 times)
Swatwolf
  • Last login:April 18, 2020, 02:27:44 am
« on: April 19, 2008, 05:48:26 am »
Heya all,
I am looking for a talented person to create a control panel from my Mameroom software template that I designed in a form of plexi or lexan. The main problem is I am wanting this to be made out a plastic transparent material that I could later attach a control panel template to. I contacted a few local places in Colorado, but wanted to try the experts in here first.
javascript:replaceText(' :dunno', document.forms.postmodify.message);
I dunno!
Video Games Currently owned and running: Mania Challenge, X-Men (Children of the Atom), A.P.B.
In the works Mame Trek (Scratch Built), Donkey Kong Jr. (Just got a PCB for)
Mameroom
  • Last login:April 17, 2020, 04:44:15 pm
Re: Control Panel made out of Plexi or other clear material
« Reply #1 on: April 22, 2008, 02:32:01 pm »
How about Mameroom?  Email me the file (sales@mameroom.com) and I'll let you know what it will cost.
Swatwolf
« Reply #2 on: April 22, 2008, 08:56:06 pm »
E-mail sent :applaud:
BASS!
  • Just have fun.
« Reply #3 on: April 23, 2008, 04:31:16 am »
if you end up doing this, you have to post lots of pics of the awesome plexi glory that mameroom does for ya.
RoninEditor
  • Last login:April 14, 2009, 02:46:58 am
« Reply #4 on: April 23, 2008, 04:51:27 am »
How much is your quote, I'm curious because I was gonna do something like this (before going the cheaper underlay route) and there's a printshop on campus where I work, they were going to do it for me for $90, reverse printing on 30x14 plexi.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #5 on: April 23, 2008, 08:29:43 am »
You could add a limo tint inside so it looks black, but then you have a light inside and suddenly your CP lights up transparent.
massive88
« Reply #6 on: April 23, 2008, 10:11:06 am »
I vote for this as well, and many build pics, and videos of it when done.
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
« Reply #7 on: April 23, 2008, 11:58:07 am »
wouldn't 3/4" lexan be quite expensive?
Swatwolf
« Reply #8 on: April 23, 2008, 06:41:40 pm »
Sent the control panel to Mameroom, I am like everyone else have no clue on the cost. Will let ya all know, here is my finalized CP design that I plan to illuminate
massive88
« Reply #9 on: April 25, 2008, 03:11:18 pm »
I love it.  Good luck!
Franco B
« Reply #10 on: April 25, 2008, 04:16:35 pm »
Good luck with it.
Are you talking about the whole CP made or just the CP top?
If you are just talking about the CP top (hell, even if not) I still think you could use the method I suggested to insert plexi pieces into the CP top for the individual segments and then back light them with LEDs. Imagine the boot up/attract sequence you could have using each segment!  8)
dmworking247
  • Last login:July 14, 2024, 01:30:59 pm
« Reply #11 on: April 28, 2008, 07:43:47 am »
Good luck with it.
I agree, I'd mount plexi on MDF but cut out spaces in the MDF to allow light to pass through. This would save cost and give you the option of different colored/independent lighting circuits.
Swatwolf
« Reply #12 on: April 28, 2008, 11:34:07 am »
Thats not a bad ides, do a normal panel, then where the graphics are just cut out squares and use lights under it...hmmmmm
See thats what I liked about this place large brains in action      :applaud:
jace055
  • Last login:August 22, 2025, 09:32:12 pm
« Reply #13 on: April 28, 2008, 08:25:21 pm »
I like this idea.  The input I have is with the diffusion of the LED light.  Experiment with the graphic and see if light will come through evenly like it should.  How about 1/2" MDF with cutouts for the lighted areas, then 1/8" plexi/ lexan lightly sanded for a more diffused look with the LEDs.  Then the graphic and then the final layer of plexi/ lexan on top.  this would also sandwich the graphic between two layers of plexi/lexan to make sure it doesn't sag in the areas the wood is cut out.
The edge might need some attention to look right.  Maybe offset t-molding.  ( 1/2" wood plus 2 x 1/8" plexiglass / lexan = 3/4" total width)
