Author Topic: Lock Picking?  (Read 5171 times)
  • Last login:February 05, 2026, 10:50:22 am
Lock Picking?
« on: April 18, 2008, 03:16:08 pm »
So...  I need to get into the locks on the stuff I just bought at the superauctions...
1) The back box of the Spanish Eye's pin.  The coin door lock is out already.
2) All three locks on the Popeye Cocktail
3) Two locks on the Capcom Impress:  The coin door, and the door directly underneath that.  I have the key to the door that houses all the JAMMA stuff, but it doesn't open the other two.
Anyway to somehow pick any/all of these locks?  I'd like to be able to unbolt them and replace them that way...  I want to avoid drilling if I can.
If I have to drill, what's the best way to go about that?  What size bit, etc?
 :banghead:
FrizzleFried
    • Idaho Garagecade
Re: Lock Picking?
« Reply #1 on: April 18, 2008, 03:20:55 pm »
 :banghead:
#3 reach through the back of the cabinet and unbolt the lock (at least the top one) from the backside.
Drilling a standard lock takes all of about 30 seconds.  I usually go with a 1/8" bit or 3/16".  Drill right in to the keyhole.  Once you get a nice hole in there if it hasn't come off already,  stick a big ass screw driver in there,  attach a nice sized vice-grips to the handle and twist.
« Last Edit: April 18, 2008, 05:04:11 pm by Peale »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Lock Picking?
« Reply #2 on: April 18, 2008, 03:23:29 pm »
go in through the door you opened and unscrew the locks!
NO MORE!!
shardian
  • Trade Count: (+23)
Re: Lock Picking?
« Reply #3 on: April 18, 2008, 03:24:21 pm »
Don't bother with lockpicking, especially if they are the tubular locks. You can'r reuse them anyways...unless you want to pay a locksmith big bucks to re-key locks for far more money than you can buy new, matching ones. I prefer all of my games to take the same key for every door.
Use a good drill bit rated for metal and go at it. For tubular locks, you have to drill all the way around the middle part to get it loose. A standard lock takes 20- 30 seconds, a tubular lock takes 1-2 minutes.
shardian
Re: Lock Picking?
« Reply #4 on: April 18, 2008, 03:25:03 pm »
Besides, drilling locks is really fun and stress relieving after a crappy day!
Re: Lock Picking?
« Reply #5 on: April 18, 2008, 03:26:47 pm »
I tried that... the gap is too small to fit my hand/tools...
Re: Lock Picking?
« Reply #6 on: April 18, 2008, 03:27:31 pm »
Sounds good...   ;D
Ken Layton
  • Guru
  • Technician
Re: Lock Picking?
« Reply #7 on: April 18, 2008, 06:05:39 pm »
 :banghead:
#1 Williams used Fort Lock key # L288 on all their back doors during that time. Check with Marco Specialties and Steve Young's Pinball Resource as well as local lockshops about ordering the key.
#2 Nintendo used  a Japanese knockoff of an ACE lock. Key # K6510 opens all cabinet locks except the cash door.
#3 I've never heard of. Probably all keyed individually locks.
Picking tools are available at:
www.lockpicktools.com and www.lockpicks.com
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
Re: Lock Picking?
« Reply #8 on: April 19, 2008, 04:31:26 pm »
I think this would be the fastest option.
Unfortunately it would yield alot of clean up. :laugh2:
Ummon
  • Trade Count: (+13)
Re: Lock Picking?
« Reply #9 on: April 23, 2008, 12:11:08 am »
I'm having the same problem on my Impress' control panel locks. I tried what are supposed to be metal drill bits, and they hardly touched the lock. Also, it's almost impossible to get hands underneath into the panel. As for the coin box door, it's a different key than the top door and there's no way to get into it. If you remove the game board partition, you can get to coin box, maybe enought to force the lock upward.
Yo. Chocolate.
Stephen Hawking
shardian
Re: Lock Picking?
« Reply #10 on: April 23, 2008, 01:49:55 pm »
Did you use the ones with the little point tip? Those are 'supposed' to be for metal but they suck. I got a drill bit set at Walmart that drilled like butter. It is Black and Decker brand, costs around $10, and has all the bits from tiny to a bit over 1/4". All of the bits are gold colored.
Ken Layton
  • Guru
  • Technician
Re: Lock Picking?
« Reply #11 on: April 23, 2008, 06:12:07 pm »
Sounds like your locks are case hardened steel. Regular drill bits won't touch 'em. Get cobalt bits.
Ummon
Re: Lock Picking?
« Reply #12 on: April 24, 2008, 03:42:30 pm »
I think mine are cheap, but they're not tipped like that. They're just black and cylindrical.
That's what I was thinking, as they look tempered or whatever. I called a locksmith and they said it'd be about $33. Not bad I guess.
« Last Edit: April 25, 2008, 05:32:19 pm by Peale »
Yo. Chocolate.
Stephen Hawking
northerngames
  • Trade Count: (+18)
Re: Lock Picking?
« Reply #13 on: April 25, 2008, 10:05:29 am »
if a drill wont do it use a dremel cut-off wheel and make a big + cut on the face and then stick a flathead screw driver in the + and twist and the face along with the guts should come off in peice's.
SirPeale
  • Green Mountain Man
Re: Lock Picking?
« Reply #14 on: April 25, 2008, 05:33:10 pm »
$33?!?  You can totally do it yourself.  Just get a hardened bit.
Ummon
Re: Lock Picking?
« Reply #15 on: May 03, 2008, 09:17:30 pm »
OH YEAH! I borrowed HarumaN's key and found out it opened one side....um, but what about the other. Of course these locks retain the key when unlocked. HM. A local guy mentioned to me that these locks could sometimes be picked with tubing or a pen cap. No dice on those...but I thought, hey maybe tape would work around HarumaN's key! So I wrapped a small bit of painter's tape around it, jammed it in there, fiddled with it - and it worked! Fortunately, the cab is plastic so it flexed and I was able to lift it above the lock. The other didn't need tape of course. Nasty 'ol locks.
Yo. Chocolate.
Stephen Hawking
Re: Lock Picking?
« Reply #16 on: May 03, 2008, 09:27:09 pm »
Hmm...  I might have to try that trick on the other doors once I get the key back... :)
shardian
Re: Lock Picking?
« Reply #17 on: May 03, 2008, 11:27:04 pm »
Next time you have to do this, get a flathead screwdriver that's got a square handle.
Hammer the screwdriver blade into the keyhole.
Take a large socket that fits over the screwdriver handle.
Get your longest wrench, or use a cheater bar.
POW.  You're in.  :D
That would work great...if these weren't barrel locks.
deeesss
  • <Banned>
  • Trade Count: (-1)
  • Last login:June 10, 2008, 10:56:45 pm
Re: Lock Picking?
« Reply #18 on: May 04, 2008, 04:18:04 am »
yeah, works great
Ummon
Re: Lock Picking?
« Reply #19 on: May 04, 2008, 10:07:46 pm »
    I think I was smoking crack yesterday. Something about the lock thing didn't sit right. So I took the key back to it with no tape. Easy peasy. Hmm. Tried tape into the token box lock. No go. HM. I think the lock flange was just jammed or something against the bar. I'd used a hammer to push the key all the way in and that likely loosened it. At least I got it open, though. (The token box lock I'm not worried about getting into - but in case I do care, just for fun I tried to see if I could force it upwards from the inside and I got it at least half way. I didn't go to town.)
« Last Edit: May 04, 2008, 10:12:21 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
Re: Lock Picking?
« Reply #20 on: May 04, 2008, 11:09:38 pm »
You can remove the nut that holds the arm on... that's how I got the locks off the coin door, and the coin box door...
take out your pcb, remove the pcb tray, and you'll see the coin box area encased in metal.  If you take out the screw and two nuts holding the metal 'collar' around the front of the coin box, you can manuever a small socket wrench in there to remove the nut.  Inside my coin box was another coin mech, the manual to the Capcom Impress (in Japanese, not much use), and some pricing stickers to go next to the coin slot (all in Yen, lol).
Re: Lock Picking?
« Reply #21 on: May 04, 2008, 11:10:39 pm »
One more pic:
Ummon
Re: Lock Picking?
« Reply #22 on: May 06, 2008, 04:01:05 pm »
Cool. I thought of removing the divider so I could fit a computer case in there and then I though it might be neater if I decased and mounted.
Yo. Chocolate.
Stephen Hawking
ablizno
  • Last login:August 15, 2011, 09:04:29 pm
  • [insert text here]
Re: Lock Picking?
« Reply #23 on: May 07, 2008, 12:11:00 am »
Those Yen stickers are awsome.
Re: Lock Picking?
« Reply #24 on: May 07, 2008, 07:29:18 am »
Yeah, I thought so too!  Once I get the cabinet completely clean, I'm going to put one on there.   :cheers:
krazy_kenny1
  • Last login:May 20, 2011, 11:14:32 am
Re: Lock Picking?
« Reply #25 on: May 17, 2008, 10:20:02 pm »
I guess I'm the only one here that did just pick the locks when I bought my cab? ::)
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
Re: Lock Picking?
« Reply #26 on: May 18, 2008, 10:06:39 pm »
Not really,
just the only one to admit it in the forum.
krazy_kenny1
Re: Lock Picking?
« Reply #27 on: May 19, 2008, 10:18:30 pm »
Not really,
:dunno
