Author Topic: Very first cabinet from scratch  (Read 3600 times)
shiftybill
  • Last login:September 24, 2011, 09:09:35 pm
« on: April 18, 2008, 04:07:26 am »
Hello,
A few friends(one of which is a carpenter) and I are getting together to build a cabinet.  I would like some feedback on the plans I have drawn up particularly how the control panel should be constructed, should it be a box or just a flat piece of wood?  The cabinet is 1 meter wide.
Thank you for your time.
285,100 - Donkey Kong High Score
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
Re: Very first cabinet from scratch
« Reply #1 on: April 18, 2008, 08:46:01 am »
I think you are going to hit your head on the marquee.
I would move it back.
As far as the CP goes, With the cab being a meter wide, you have room  to make it a flat panel.
You just need it removable to install the controls.
I used a scrap peice of wwod to layout the controls first to make sure I was happy with them.
Than build the real thing and work on the CP graphics.
Good luck
BG66
Half of the people you meet are below average.
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #2 on: April 18, 2008, 08:47:20 am »
Welcome!
If your control panel is not wider than the cabinet and does not hang forward, then you can go with just a flat piece of wood. Otherwise you'll need a box design.
Robots will kill you.
Arcade Addiction
Dudeman
  • Last login:April 23, 2025, 06:42:24 pm
  • Ecky ecky ecky ecky P'Tang! Zoop-boing mmmzoesm...
« Reply #3 on: April 18, 2008, 11:20:48 am »
I would straighten out those buttons. That angle will make it hard to play some games. Especially SF or Mortal Kombat.
shiftybill
« Reply #4 on: April 22, 2008, 06:04:56 am »
Thanks for the tips guys, we have successfully cut out the pieces of MDF and will assemble it this weekend, and no head hitting the marquee  :)
I will have pics of the build this weekend
I also updated my control panel plans, please see attached.
Thanks guys!
Dudeman
« Reply #5 on: April 22, 2008, 09:43:50 am »
You may have read this before, but it bears repeating.
Make a test CP out of cardboard or hardboard and play on it a bit to make sure you like (read: you hands don't cramp up) before you cut your final piece.
Good luck and let's see the pics!
Encryptor
  • Trade Count: (+34)
« Reply #6 on: April 22, 2008, 04:15:14 pm »
At 1 meter wide is it going to fit through a standard doorway? Most are around 29".
Encryptor
shiftybill
« Reply #7 on: April 23, 2008, 02:16:47 am »
Thats a very good point Encryptor, thank you so much for poiting that out!  I will make the cabinet thinner.  With a thinner cabinet i will have to make a box for my control panel that is detachable (interior latches) so the controls dont get to cramped when 2 people are playing.  I will update my plans and post my thoughts, thanks again guys!
shiftybill
« Reply #8 on: April 25, 2008, 03:40:39 am »
Hiya guys,
Had a great time assembling the cabinet today, still need to do a bit tomorrow (angle cuts).  Heres a pic of what it looks like so far
Update:  I got a free 21" CRT from work today  :applaud:
I put wheels on the cabinet, filled in all the gaps and am almost ready to begin painting
Update2:  I put an undercoat of paint on and am about to drill the holes on my CP :D
« Last Edit: May 03, 2008, 01:20:26 am by shiftybill »
shiftybill
« Reply #9 on: May 04, 2008, 12:26:54 am »
Hey Guys,
I just finished the 2nd coat of paint and thought id share a few pics  :cheers:
Update: I painted the 1st coat of Glossy Black paint, it will need another one or 2 coats
Update2:  Added another coat of black paint one more coat and that should do it
Update3:  I just purchased all the joysticks and buttons and i got an old pc yesterday, dual P3 1Ghz!!
Update4:  The painting is all done, the control panel is in place, waiting for my joysticks and buttons to arrive :applaud:
Update5:  The joysticks and buttons arrived the other day, I had quite a time installing and programming it, but after a bit of tweeking and many a foul word it all works perfectly!
« Last Edit: May 12, 2008, 04:37:55 am by shiftybill »
shiftybill
« Reply #10 on: May 14, 2008, 08:32:57 am »
Hello,
Heres some pics of the cabinet
I still need to attach the door, get a marquee and bezel, and then I can decorate, im still thinking of a theme
« Last Edit: May 14, 2008, 09:36:12 am by shiftybill »
shiftybill
« Reply #11 on: July 15, 2008, 01:33:53 am »
Hello,
I finally attached the door, and the marquee is on its way!
Heres a pic f what it looks like so far
spacies
« Reply #12 on: July 15, 2008, 08:46:26 pm »
You are almost done buddy.
Keep truckin'  ;D
