Author Topic: Atari 33" showcase cabinet  (Read 2707 times)
computarmann
  • Last login:February 20, 2014, 12:42:46 pm
« on: April 17, 2008, 10:02:23 am »
    I found a 33" showcase cabinet with point blank 2 in it for $250 (Is this a good deal?). I have a few questions. I looked on KLOV and searched net for information on Point Blank 2 and I can't seem to find whether it was a standard or med resolution game. The monitor in the game looks perfect but is this a med resolution monitor. Did Atari showcase 33" come standard with a certain kind of monitor or was the cabinet sold alone. If this is a medium resolution monitor does advance mame work well with it for older games. Do I need a signal booster to get the signal to a higher level from say the ipac device if I were to use advancemame with a med res monitor? I hooked up a computer using soft 15khz to my cherry master machine monitor and the picture was very dim is this a symptom of a signal needing boosted Could there possile be a Wg 9400 in the cabinet already or is this just dreaming. Anyway $250 does'nt seem bad for such a great cabinet.
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
Re: Atari 33" showcase cabinet
« Reply #1 on: April 17, 2008, 10:35:05 am »
The majority of showcase cabs I have seen came with a Sharp Image monitor, either a SI series or KT series (rebranded Kortek).    The resolution depended on the game.
I seem to recall that Point Blank 2 had switchable resolution, but I could be wrong.
So really there could be any monitor in that cab, might even be a switchable res monitor.  The only way you are going to know for sure is to look at it, get a model number or pic of the chassis.
As for the price,  $250 seems like a very good deal.  Regardless of the monitor type, if the tube is still bright and sharp the monitor itself is probably worth that.  33" monitors ain't cheap!
D
northerngames
  • Trade Count: (+18)
« Reply #2 on: April 17, 2008, 02:26:28 pm »
yeah a working showcase for $250.00 is a steal no matter what type monitor as long as it works.
most the larger display's are duel or tri res usually.
like mentioned above get a picture if possible or worst case if it is not the res you need sell it and get a gateway destination DL-31 or DL-33 vga or something
