Author Topic: Ways to install a removable base  (Read 1119 times)
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
« on: April 16, 2008, 04:27:12 am »
I have these two methods for attaching the base of my panel. It will be a board made of iron: 57 cm x 27 cm x 2 mm. Have you tried any of them? The one on the left has a problem. Apart from the fact that it's a little big, although usable on my 19 mm MDF board, I've tested it and sometimes, when you unscrew, the female piece comes up together with the screw. I suppose adding some glue will be the solution. The other one has the problem that you cannot have the screws installed in a very low level, like with the first one. Here's the photo:
rackoon
  • Last login:January 05, 2026, 12:26:30 pm
  • I EAT PENCILS!
Re: Ways to install a removable base
« Reply #1 on: April 16, 2008, 04:43:25 pm »
Why do you want to remove the base? I think if you add some more info you will get more responses :cheers:.
They treated me like an animal and that's what I became.
