Author Topic: Arkanoid to Mame project.  (Read 21554 times)
ablizno
  • Last login:August 15, 2011, 09:04:29 pm
  • [insert text here]
« on: April 15, 2008, 04:34:17 pm »
Just picked up my Arkanoid cabinet. Im going to start converting it this weekend. I will post pictures of the convertion, so don't worry. Just one question, there is a black push button next to the coin door, what is this for and is there a way to remove it and make it appear as if it was never there? Also i added a picture of this mysterious button (probably a credit button)
« Last Edit: April 18, 2008, 07:53:38 pm by ablizno »
Re: Arkanoid to Mame project.
« Reply #1 on: April 15, 2008, 05:02:20 pm »
next to the coin door meaning there's a hole in the plywood?  Use a plug and some bondo and sand it back (or just bondo if the hole is small enough).  If the hole is in the metal on the coin door, I can't help you there...
ablizno
« Reply #2 on: April 15, 2008, 05:26:20 pm »
Yeah, there is a black pushbutton in the wood near the coin box. I dont have my camera or i would take a picture of it.
phishpac
  • Last login:October 15, 2009, 10:42:19 am
    • grateful arcade
« Reply #3 on: April 15, 2008, 07:06:50 pm »
** offers ablizno flame retardant suit **
ablizno
« Reply #4 on: April 15, 2008, 07:11:19 pm »
@phishpac why would i need that suit? :dizzy:
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
« Reply #5 on: April 15, 2008, 08:25:03 pm »
folks 'round here don't take too kindly to people maming classic arcade cabs.
[cue banjo music]
in this case, i don't think people will care too much...  arkanoid is a classic, but calls no cabinet home - - they're all conversions.
ablizno
« Reply #6 on: April 15, 2008, 09:22:22 pm »
Don't worry the guy i bought it from said it has undergone several conversion. BTW what is the best paint to get the cabinet a nice glossy black?
phishpac
    • grateful arcade
« Reply #7 on: April 15, 2008, 10:35:21 pm »
i used an interior semi-gloss latex
ablizno
« Reply #8 on: April 16, 2008, 09:33:15 am »
What would be the best way to apply that without getting streaks? I want it to look very sleek. The Home Depot by my house sells a very shiny epoxy spray paint but that is for appliances.
« Reply #9 on: April 16, 2008, 09:52:12 am »
I just posted this somewhere else on the main page:
How much work are you willing to put in?   >:D
ablizno
« Reply #10 on: April 16, 2008, 10:46:14 am »
@javeryh im kind of on a low budget, but i still want it to look as nice as possible.
« Reply #11 on: April 16, 2008, 10:58:24 am »
I don't think budget has much to do with anything although the way I finished my last cab will run you a little more in terms of minor supplies like sandpaper, lacquer and rubbing compound.  You really need patience though because it takes forever.
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #12 on: April 16, 2008, 11:31:58 am »
post a pic of the cab so when can see what it really is.
also, no one said it but my guess is the button by the coin door would be a
...................drumroll.........................................
credit button   :applaud:
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
ablizno
« Reply #13 on: April 16, 2008, 11:56:03 am »
@lutus i thought the same thing to myself. I cant find the damn battery to my digital camera. I will pick one up tomorrow and will be sure to take some pictures.
Lutus
« Reply #14 on: April 16, 2008, 12:33:34 pm »
Here in town there is an arkonoid in a bump-n-jump cabinet.   :'(
with the bump-n-jump sideart somewhat still intact
ablizno
« Reply #15 on: April 16, 2008, 10:14:02 pm »
Just decided that i am going to go with a Phenomenauts theme.. anyone have suggestions to make the cabinet look like it has stars all over it?
SirPeale
  • Green Mountain Man
« Reply #16 on: April 17, 2008, 10:00:47 am »
http://www.spacetoys.com/proddetail.php?prod=TGK59
ablizno
« Reply #17 on: April 17, 2008, 11:02:44 am »
@peale i dont mean like that, i ment like a star field, as if your actually looking at the sky, but thanks
ablizno
« Reply #18 on: April 18, 2008, 12:05:34 am »
How do i repair water damage?
« Reply #19 on: April 18, 2008, 11:35:23 am »
A pic would help greatly.  Most likely you would use a saw to cut out the damaged area, cut a new piece out of plywood, glue/screw it into place and use bondo and sandpaper to smooth everything out.
ablizno
« Reply #20 on: April 18, 2008, 07:54:56 pm »
Here is a picture of the water damage
SirPeale
« Reply #21 on: April 20, 2008, 05:58:30 am »
I know.  I was trying to be funny.
FUNNY NOT FOUND.
ablizno
« Reply #22 on: April 20, 2008, 08:53:37 pm »
Update: well the paint is hard as hell to sand off, im using one of thoughts electric rotating sanders, the outside coat is just too tough. Tomorrow my buddy is coming over bringing his belt sander, after its sanded ill post some pictures. Also the underlying coat is blue, cant make out any graphics, any ideas
edit: just thought i would add that i found 2 US quarters, 2 Canadian quarters, and 1 token jammed in the coin door. ALso whats the best way to get it functioning properly, its kind of hard to eject coins, and coins get stuck going in.... WD-40?
« Last Edit: April 20, 2008, 10:33:38 pm by ablizno »
SirPeale
« Reply #23 on: April 21, 2008, 06:10:31 am »
WD-40?
No!  No, no, no, no...no.  Noooooooooooooo. Just make sure everything is clean.  Possibly use some graphite.
ablizno
« Reply #24 on: April 21, 2008, 10:29:15 am »
@peale whats so bad about WD-40? :dizzy:
Paladin
  • Mmmm llamaburgers!
« Reply #25 on: April 21, 2008, 11:30:04 am »
Ummm... am I the first one to notice what that cab originaly was?
ablizno
« Reply #26 on: April 21, 2008, 12:38:53 pm »
@paladin that would explain the blue underpaint
SirPeale
« Reply #27 on: April 21, 2008, 04:34:53 pm »
It gums after a while.  Gum =  stick.  Just what you do NOT want a mech to do.
ablizno
« Reply #28 on: April 21, 2008, 11:26:43 pm »
Ok so the control panel is alluminum and has latche which hold it onto the cabinet. I think its pretty bad ass and would like to keep it. The problem is that when i re drill the holes, how do i fill in the old ones. I will be placing a new layer of plexi over the control panel once the graphic is applied. My concern is that the graphic will sink into the old holes, even if i put aluminum under them, makeing them visible once again. would bondo help.. the putty not the fiberglass stuff.
Paladin
« Reply #29 on: April 22, 2008, 09:51:22 am »
You should offer the parts and/or whole cabinet for sale.  There's been talk on the KLOV forums lately about Journey cabinets, and your cabinet looks completely restorable.  I don't know what the value of an empty Journey cab is, but it may be worth your while to post it and ask for offers.  You never know, you may find someone in your area who would trade for another empty cab plus cash.
I'm suprised no one has posted about saving this cabinet.  Usually when someone wants to convert a semi rare classic cabinet everyone jumps all over them.   Personally, I think it's your cab to do whatever you want with - but as I said you might come out ahead if you post a for sale post making sure to call it a 'converted Journey cab'.
FrizzleFried
    • Idaho Garagecade
« Reply #30 on: April 22, 2008, 11:01:52 am »
Yessirreee that is a Journey cab you have there.  It was a sin to convert it to begin with but to MAME it?   If you were smart,  you'd offer it up for TRADE...I bet you could get a cab with a 25" monitor from someone interested in restoring that Journey back to it's original glory.
Be vary wary of angering the arcade gods BTW...
shardian
« Reply #31 on: April 22, 2008, 11:06:56 am »
I just saw this thread and as soon as I saw the bezel, I recognized it. The bezel is worth some pennies, especially in that good of shape. I was shocked there were as many posts here without someone mentioning it.
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
« Reply #32 on: April 22, 2008, 11:32:21 am »
Hey ablizno,  If you are anywhere close to Atlanta GA, I will trade you a MAME-able cab for the Journey cab... or offer you cash or a new clean piece of bezel glass for the Journey bezel glass.  I am restoring a Journey and I don't have the glass, and the bezel artwork is not available anywhere.
Or you could try to get the glass artwork scanned somewhere and contribute that to the forums.
Just a thought...
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
amadama
  • Last login:September 29, 2019, 04:44:52 pm
« Reply #33 on: April 22, 2008, 11:52:22 am »
I just PM'ed ablizno to see if he's open for a trade or sale (if he's local to me in NY).
I've been looking for a journey cab for a while now. At least a scan of the bezel would be nice for a home-brew journey.
ArtMAME
    • Art's Arcade Lab
« Reply #34 on: April 22, 2008, 01:04:49 pm »
Yeah, I PMd him to see where he is... If he is in NY, then that is nowhere near me... oh well.
  I do have a Journey cabinet, all I need is sideart, bezel, CPO, and marquee...
amadama
« Reply #35 on: April 22, 2008, 01:40:15 pm »
I have CPO and marquee files, I need the bezel and sideart.
I have been asking around people to get good pics of this stuff (even offering $20 for the photos!) and no takers!
ArtMAME, can you post pictures of you cabinets? I'd like some measurements to make a blueprint for a scratch built one.
Thanks,
Alex
ArtMAME
    • Art's Arcade Lab
« Reply #36 on: April 22, 2008, 03:58:58 pm »
Sure Alex.  I know that Buckethead also wants to do a scratch-built one.
My garage is packed to the gills right now but I am unloading a couple of cabs here in the next week.  I will be able to pull out the Journey cab (which I got as a Tetris conversion) and make a measured drawing of it.
Let me know when you finally get the bezel image file.  I am going to restore the cabinet with a cpo and marquee and maybe hold out for some accurate sideart and bezel repros.
amadama
« Reply #37 on: April 22, 2008, 04:17:33 pm »
PM me your email and I'll send you the marquee and CPO files.
ablizno
« Reply #38 on: April 22, 2008, 09:37:29 pm »
Sorry but i really like the design of this cabinet, it only cost me 75 dollars so it was a steal. Sorry that i am not restoring it but i feel that it is nothing compared to the individual converting a Galaxian cab.
amadama
« Reply #39 on: April 22, 2008, 11:17:06 pm »
Ablizno,
Can we ask you to take some good pics of the glass bezel (with the Arkanoid sticker removed)?
Also, does your machine have the original Journey side art? We need some pics of that too.
Alex
