Author Topic: Arkanoid to Mame project.  (Read 23157 times)
ablizno
  • Last login:August 15, 2011, 09:04:29 pm
  • [insert text here]
Re: Arkanoid to Mame project.
« Reply #80 on: May 24, 2008, 12:04:52 am »
So im gutting my pc to put it into the cab, for heat reasons, and im running into the problem of the perifial  cards (and some solder points on the motherboard) hitting the wood. No hardware store in the area sells spacers.  I was going to use metal washers but fear that that may cause a short, any suggestions.
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
« Reply #81 on: May 24, 2008, 03:34:32 am »
If you get a Bic pen like the one in the link:
http://www.wackypackages.org/stickers/4th_2006/realproducts/bicpens.jpg
You can pull out the cartridge, then cut the hollow plastic tube into 1/2" pieces and use them as spacers.  just use 1" wood screws or 1" sheet metal screws.
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
GAJoe
  • Last login:September 05, 2012, 03:35:51 pm
  • Bluster Blaster will DESTROY YOU!
« Reply #82 on: May 24, 2008, 09:47:15 am »
That's a brilliant idea.  That's going in the mental filing cabinet for future reference.
ablizno
« Reply #83 on: May 24, 2008, 05:34:19 pm »
Awsome idea i will try that later tonight if i get around to it.
IDDQD
  • Last login:December 02, 2020, 12:13:47 am
« Reply #84 on: May 27, 2008, 03:34:14 pm »
I haven't read anything about this, but do most people take the computer out of the case and just mount it in their cab for heat reasons? I've seen a number of people do it, and come to think of it I haven't seen anyone not do it, so is that pretty standard practice?
ablizno
« Reply #85 on: May 28, 2008, 09:01:56 am »
@iddqd i would say yes. This is my first mame cab and it just made sense to me to do so. Then upon wondering the forums i saw others had done so as well.
ArtMAME
    • Art's Arcade Lab
« Reply #86 on: May 28, 2008, 07:33:43 pm »
I usually just put the whole PC in the cabinet and secure it in there.  I have not experienced any heat problems with my systems.  I usually get off-lease PCs which are ready to go.
IDDQD
« Reply #87 on: May 29, 2008, 12:16:02 pm »
Do you do anything about ventilation, like cutting exhaust holes in the back and putting the exhaust ports in the PC against those holes? Or is it fine without anything like that? I'm thinking I'm probably just going to put the whole thing in there, becuase my case has a bunch of fans and I'd like to use them.
GAJoe
« Reply #88 on: May 30, 2008, 02:26:09 pm »
My system was overheating and shutting off in the case.  When I took it out and mounted it bare the problem went away.  My cabinet already had ventilation built into it for the original PCBs and monitor, so that wasn't necessary.
