Author Topic: mdf/wood control panel  (Read 5386 times)
ablizno
  • Last login:August 15, 2011, 09:04:29 pm
  • [insert text here]
« on: April 13, 2008, 11:20:17 pm »
what is the best way to attach a control panel overlay from www.mamemarquees.com to a wood control panel. I will be using the adhesive polycarbinate laminate overlay.
amadama
  • Last login:September 29, 2019, 04:44:52 pm
Re: mdf/wood control panel
« Reply #1 on: April 17, 2008, 09:03:48 am »
Paint the CP with primer first then a quick sanding. You should then be ok to apply the overlay to that. I did it once without a primer coat onto the raw MDF and after about six months it started to peel off.
Good luck!
Alex
ablizno
« Reply #2 on: April 17, 2008, 04:37:45 pm »
Its ok im just going to use aluminum and lay a piece of plexi over top, but thank you.
Blanka
« Reply #3 on: May 12, 2008, 11:16:09 am »
Why plexi? Try to find anodised aluminium. Nice and strong finish, no oxidation and nice looks without the need for a transparant layer on top.
Jdurg
« Reply #4 on: May 12, 2008, 12:53:44 pm »
Because the artwork isn't exactly durable and if you have bare artwork on top of the CP it will certainly get marred, scratched, ripped, etc. after many hours of abuse.  It's MUCH easier and cheaper to replace the plexi than it is to replace the artwork.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
Blanka
« Reply #5 on: May 12, 2008, 01:20:46 pm »
Something went wrong here. I did not get the first 2 posts. So I did not know you were about using artwork  :banghead:
