Author Topic: Marquee light issues  (Read 1217 times)
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« on: April 02, 2008, 04:15:54 pm »
I made a temporary marquee and noticed a couple of irritating issues:
Light is seeping out from the sides of the acrylic panels, and the edge of the wood inside is casting a shadow. I was thinking of using a strip or two of electrical tape to cover the edge of the acrylic which should hide things; or maybe cutting thin strips of black plastic. Has anyone else had this problem?
(Or maybe it's just the thin printer paper I used?)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
joshlindem
  • Last login:July 23, 2025, 11:35:39 pm
Re: Marquee light issues
« Reply #1 on: April 02, 2008, 04:37:13 pm »
I'm not expert in this, but here's an idea....
On the sides of the marquee, what if you ran a black marker down the sides.  I'm betting your marquee display covers the back, but perhaps not the sides and that's where the light is seeping from?
That makes sense?
TelcoLou
« Reply #2 on: April 02, 2008, 04:51:03 pm »
That makes sense?
AH ... indeed it does, thank you for the tip!  :cheers:
somunny
  • Is it hot in here?
« Reply #3 on: April 02, 2008, 05:08:13 pm »
Normally, I design and have my marquee printed up approximately 1/4 - 1/2" wider than I need.  The extra amount folds back over the plexi on each side and blocks any light that may try to seep out.
TelcoLou
« Reply #4 on: April 02, 2008, 05:11:15 pm »
Brilliant!! Thanks so much!! ..  :notworthy:
