Author Topic: T stick or E stick?  (Read 1222 times)
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
T stick or E stick?
« on: May 26, 2003, 05:34:52 pm »
Ok I have a 4player panel. Players 3  1  2  4
Players 1 and 2 are P360s so what should I make player 3 and 4's?
I want to choose between an E or T stick because 1) you can get them in black (will match player 1 and 2) and 2) Because they can be converted to a 4-way (which I want on my cab but didnt want to place a seperate 4 way in addition to the other 4 joysticks--would be to cluttered!) So which one do you think?
Also is it easy as Ultimarc's website says--literally a switch? So I just open my panel up (will be hinged to open with ease) and flip a switch and I'm done?
Thank you for all your replies.
Derek
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re:T stick or E stick?
« Reply #1 on: May 26, 2003, 06:40:35 pm »
The T-stick has the 4/8 way switch, but the E-stick does not.  The E-Stick switches by reaching underneath and rotating a switchplate.  See here for more info.
crashdmj
  • Hulk smash!
« Reply #2 on: May 26, 2003, 11:28:56 pm »
Ok thanks Sasquatch! I guess that white portubance (sp??) on the T-stick is the switch so I would be able to switch it when I open the control panel, right?
Derek
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
« Reply #3 on: May 27, 2003, 04:56:17 pm »
T-stick may look better.  It has a larger handle and shaft...
I have both of them though, and each seems very sturdy and well made.  Both are easy to switch from 4way to 8way.  The T-stik with the "toggle switch", the e-stik with a rotation plate.  Also, the e-stik works well with q-bert as you can turn the switch plate 45 degress.
...they only live twice!...
(>")>----MAME----<("<)
